HELP: Lug nut stud - Bimmerfest - BMW Forums
Old 07-23-2013, 06:12 PM
BKMBMW BKMBMW is offline
Mein Auto: 2006 330xi
HELP: Lug nut stud
I went out today to go to work. I looked down and one of my lug studs is gone. How hard is it to DIY? I have access to shop with tools on base. Also what are the issues with driving the car?
Sent from my SAMSUNG-SGH-I747 using BimmerApp mobile app
Old 07-23-2013, 06:26 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Check the rest of them first.
If you have a breaker bar to change a flat (some E90's don't have this)
Tighten the rest of them down before setting off, you don't know how that one was lost.
The car can be driven with one missing, but you should get one and install.
Kinda weird that you looked down and saw one missing, someone after you or did you literally just looked down and saw it?
Old 07-23-2013, 07:06 PM
I actually did tighten down the other ones. LOL no one is after me. I just did a PCS (military move) to my new duty station.
Old 07-23-2013, 07:13 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
It is a lug bolt, not a stud. Just get a new one, put it in and torque it.
Old 07-23-2013, 07:14 PM
Not the bolt itself, the actual screw that the bolt goes on is missing.
Old 07-23-2013, 07:23 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
It is opposite of American cars, the missing part is the bolt, the car just has a threaded hole and you put the lug bolt on with the wheel, not like other cars where the bolt stays on the car and you just use a nut.
Take another one off and then it will make sense, all you need is a new lug bolt and the lug wrench or a socket wrench to install, no special tools!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 07-23-2013, 07:26 PM
Re: HELP: Lug nut stud
Got it. Thanks for the terminology. Well herw come my firat DIY of any type.
Old 07-23-2013, 07:29 PM
Dashdog Dashdog is offline
Mein Auto: 2011 335is
I believe you are missing a wheel bolt. Unless your hubs have been converted to studs, the screw as you call it is part of the bolt. Did you buy the car used? It comes from the factory with wheel bolts, not studs and nuts. It's just one piece, and easy to replace.
Edit: too late. Just trying to help
Old 07-23-2013, 08:30 PM
I did buy it used.
Old 07-24-2013, 11:38 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
Permanent change of station,better than FUBAR.
Life is a Journey,Enjoy your ride.
Old 07-24-2013, 11:54 AM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
Old 07-24-2013, 12:11 PM
If you are at Fort Dix it might not be better than FUBAR.
Old 07-24-2013, 12:13 PM
Fort Dix is better than Fort Irwin.
