Old 07-24-2013, 05:33 PM
mrbelk mrbelk is offline
Send a message via MSN to mrbelk
Mein Auto: 07 335i/6sp
Nav system stuck "Starting"
After a long wait, I got my car back from European Delivery today.
There's a minor hiccup, though. The navigation system just says "Starting Navigation..." or some such and is stuck there. Is it possible that it takes a while for the car to relocate itself from Europe to North America? Is that the behavior the system exhibits when there are no maps loaded? Could it be that the Euro maps are still in there and it's trying to locate my car on those maps (which it never will since I am 4000+ miles from any possible place those maps might cover)?
I think they rushed the prep so I could pick it up this afternoon and might have skipped a couple steps and didn't actually load the map data. Is that something that is supposed to be done at the VDC or at the dealer?
Thanks,
-MrB
(ED 5/11/13) '13 328i M-Sport Estoril Blue II/Black, Trip Journal
(ED 5/25/10) '11 335i M-Sport Le Mans Blue/Oyster, Trip Journal
(ED 5/19/08) '08 X3 3.0si Alpine/Tobacco, Trip Journal
(ED 5/7/07) '07 335i/6sp TiAg/Lemon, Trip Journal
(ED 4/18/05) '05 X3 3.0 Blue Water/Black, Trip Journal
(ED 4/28/04) '04 545i Silver Gray/Beige
Old 07-25-2013, 11:58 AM
jjrandorin jjrandorin is offline
Mein Auto: 435 Grand Coupe MSport
Not sure of the answers to your questions, but have you tried pressing the menu key to sort of bypass actual navigation, then going in the settings to see what map version is there? That would let you know what maps you had (or if you had maps) at least, provided you can access it.
Old 07-25-2013, 12:07 PM
I did not. I couldn't hit "Options" from the loading screen, either. Should the "Menu" button have taken me to a main "NAV" menu? Where do you find the map version from the main iDrive menu, because I looked for it. I know that the delivery specialist at the Welt loaded some Euro maps via a USB stick (that I was allowed to keep) when we took delivery in Munich.
At any rate, the car is back at the dealer now getting looked at.
-MrB
Old 07-25-2013, 12:10 PM
Well, I did not have euro delivery, but when my car starts up and I get " starting navigation " (I have removed the nag screen via coding, so this is the screen I get on pressing the start button), I can press menu and see the "main menu" with radio, navigation, settings, etc etc.
I will have to check to see where I would find my nav version specifically. I will check the next time I get into the car as I do not remember the steps offand.
EDIT: So this would not have helped you because you have to be in the nav screen in the first place, but to answer the question anyway, to see the map version do the following:
1. Press Menu to return to the "Home" screen
2. Select Navigation
3. while in Navigation, push the Options button (physical button next to iDrive controler)
4. Use iDrive controller wheel to scroll down to Navigation version / System version ( can not remember exact wording but its pretty obvious which one it is at the bottom)
I have 2013 1A maps.
Old 07-25-2013, 02:00 PM
Car is done. I guess the North American maps weren't compatible with the NAV system software so they had to update the SW and reinstall the map data. Not sure if that's a correct description of the problem, but I don't really care as long as it works.
-MrB
Old 11-16-2015, 04:31 PM
beamerexperienc beamerexperienc is offline
Mein Auto: usa
BMW navigation hands
Hi Guys,
I struggled a lot to fix navigation hang issue. It started in winter season due to cold weather. I have 528xi. Here is the resolution
The issue was due to Bluetooth equipment in trunk. If you unplug the cable of the Bluetooth, you can temporarily fix the issue as you can use navigation system but no audio.
However, the best thing which completely fix the problem was, I took off the Bluetooth part from the trunk. Then opened the Bluetooth box (you can easily get a screw driver 5$). Then using a heat gun, I heated the whole circuit. Just make sure you keep moving the heat gun and don't over melt the circuit.
Then I put the Bluetooth equipment back in trunk and connected the cables. Now its been almost 8-9 months and it is working as new. This idea was pasted by someone else but I am pasting it again as it really works.
Otherwise changing that part is expensive and full of hassles.
