Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 07-26-2013, 06:23 AM
drexell drexell is offline
Mein Auto: e31 ('83 320i)
Frozen ignition cylinder
Day 2 of ownership for my new e21 (beautiful 110k 1983 320i) and I have already rendered it inoperable. When I parked last night, I had the wheel cranked to one side. This morning the wheel is locked and the ignition cylinder seems frozen. Any ideas?
Old 07-26-2013, 09:13 AM
Alright, I've decided to just drill out the spring locking mechanism for the wheel lock. I assume some of you have done this, is it any different than specified over in the E36 forums?
Old 07-26-2013, 02:33 PM
mossyoaks mossyoaks is offline
Mein Auto: 95 525it, 92 525it
Lock Cylinder
You mentioned parking with wheels turned. That puts pressure on the ignition lock mechanism. If you take the pressure off (turn the steering wheel back the other way) that will release the lock mechanism and you should be able to rotate the key.
I know this sounds pretty basic, but thought it should be offered!
Otherwise, you'll have to replace the tumbler/lock cylinder. Pretty common on our e34s. Never had it happen on an e21.
Old 07-27-2013, 05:06 AM
You can't be too obvious with me, the purpose of picking up this car was getting a project and a little education I spent a good 15 minutes tugging and twisting in the morning, but figured I'd give another go with some graphite when i got home from work. Unlocked immediately.
Possibly the worst first post ever?
Old 08-31-2013, 02:19 AM
BMWFatherFigure's Avatar
Old School
I'm sure there have been worse - nothing springs to mind though. Had you never seen your problem in another vehicle? Could not a friend help you out? Find yourself the hand book and read it cover to cover - good place to start. If your car did not come with one - try e-bay. Worked for me. Don't use too much graphite - it is a conductor and could short out the electrical contacts.
Current:
E38 Parts Car
Previous:
