Old 07-26-2013, 04:33 PM
tower06 tower06 is offline
Mein Auto: 2008 328Xi
Brake Sensor Reset
Had my pads and sensors replaced by my garage today but the red dash light is still on. How do I reset it?
Old 07-26-2013, 06:56 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Did they replace the sensor? The can't be reused.
Old 07-26-2013, 07:14 PM
MADBMWX3 MADBMWX3 is offline
Mein Auto: 2005 BMW X3
I got this from: http://www.bimmerfest.com/wiki/index...W_E46#Brakes_2 I have never tried this myself....
"If you replace the front or rear sensor as part of servicing your brakes, the WORN BRAKE PADS light will not reset by itself. To reset the light, just turn the key ON for 30 seconds. The light will go out - you're done, you can now start the car or just shut it off ."
Old 07-26-2013, 07:56 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Brake Sensor Reset
Procedure for the e90 is a little different. It involves inserting the key, holding the odometer reset button, then using the BC menu to reset the service light for the brake pads. Search around for more details.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 07-28-2013, 01:39 AM
Drooper Drooper is offline
Mein Auto: E90 E60
AFAIK you have to clear the fault and reset the usage parameter as well - can all be done with the tools in a repair shop and doesn't take 5 minutes.
Old 08-02-2013, 11:03 AM
Thanks...will give all a try.
Old 08-02-2013, 11:04 AM
Both front and rear sensors were replaced. Local shop, not dealer. Don't think they knew how to reset.
Old 08-02-2013, 11:13 AM
PeteClaw PeteClaw is offline
Mein Auto: E46
of course you need a special BMW software or a powerful general one - but the reset is definitely BMW specific
Old 08-03-2013, 12:10 PM
Mein Auto: '06 AW 330xi
The service indicators can all be reset in the cluster. No need for any special tools
Old 08-03-2013, 01:12 PM
Tried all the recommendations, and still can't seem to reset it.
Old 08-04-2013, 08:36 AM
Was the sensor aftermarket? Some aftermarket sensors are poor quality and they don't work correctly.
Old 08-04-2013, 09:38 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Whaaa?
They tried THIS?
Old 08-05-2013, 04:18 AM
Whaaa?
They tried THIS?
Sensors were brand new from BMW. Tried that link already. No Go.
Old 08-05-2013, 06:19 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
I had my rear brakes done last week. 25 miles after leaving the shop, the car on lift / brake symbol came back on.
Took it back and they replaced the brand new pad sensor with another brand new pad sensor, which seems to have taken care of it (knocking wood and insisting I'm not spitting in the face of God).
