Battery Question - Bimmerfest - BMW Forums
Old 07-26-2013, 04:33 PM
BimmerBoy1986 BimmerBoy1986 is offline
Mein Auto: 2007 335i Sedan
Question Battery Question
Need to replace the battery on my 335i. I intend on getting it registered at my Indy. Can I get away with installing it without registration for the 5 minute drive to my Indy or should I just lug it along in the morning (getting cyl 6 injector replaced)? Battery is really on last legs not holding a charge. I have it on the trickle as I type.
Old 07-26-2013, 06:55 PM
jburke4689 jburke4689 is offline
Absolutely no problem with a short drive.
Old 07-27-2013, 05:31 AM
Thanks !!!
Old 07-27-2013, 06:41 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Whatever you do, please, travel with a backup!!!!!!!!
This fine unit, for instance, will provide vehicle power in the event that your battery fails. And fail it may if not registered - improper chanrging has killed many a good unit!
Your co-pilot should operate the crank on every drive, until your battery is registered. Be certain to crank at 50-60 hz, no more and no less, through a rectifier to your changing terminals under the hood. 12 gauge wire recommended.
You will have peace of mind and, should your battery go dead, you can re-charge in even to most desolate locale!
Best o'luck BimmerBoy1986 - DO post a Youtube showing operation of the above on an actual trip!
Old 07-27-2013, 12:18 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
You forgot to mention the frabulator gasket that insulates the crank device from the vehicle.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
