Old 07-27-2013, 12:11 PM
jwb2781 jwb2781 is offline
Mein Auto: 2008 335i
Cornering lights failure! !..How can I erase this?
So I got a little water in the seal, and this light came on....I don't want to go spend $2000+ to get it fixed....is there a way to just erase the code? The lights work great, they just don't turn. Any help would be super.
Name:	bmw light.jpg
Old 07-29-2013, 06:51 AM
e92josh e92josh is offline
New Guy
Mein Auto: 2009 328i Coupe
It's not 2K. It's $500 and an Indy shop can do it. Your module for the adaptive head lights went out. a few hours of reprogramming and a new module and you're set to go. Just had it done on my car 2 weeks ago.
Old 07-29-2013, 02:08 PM
$500.....
And still $500 for a maybe fix is not what I am looking for...I want the $0 fix....again, I have taken it in, and they think it's going to cost $2000.
Old 07-29-2013, 02:09 PM
New Guy
Buy one of these:
Old 07-29-2013, 02:10 PM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Mmm, Toyota. Great choice. Run it to the ground, pay $0.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 07-29-2013, 02:12 PM
...Because I have one of these....
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
Originally Posted by e92josh View Post
Buy one of these:
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
BiHoTTo115's Avatar
Wow.
Just wow.
Old 07-29-2013, 02:26 PM
Ok, well if anyone is local, I am happy to spend $500 if it's going to fix the problem...I am not interested in paying $125+ to find out it's $1500+. I was wondering if there was a way to get around the light coming on, but it sounds like, "not without fully fixing it".
Old 07-29-2013, 09:04 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
tape the light over with masking tape ...
Old 07-30-2013, 08:20 AM
BiHoTTo115's Avatar
You jest, I would paint it with some leftover deck-protection paint (nice brown color) from last weekends yearly deck repainting. Brown is classy.
Old 07-30-2013, 02:23 PM
Mein Auto: '06 AW 330xi
If you got water inside the headlight , it's not your adaptive module. It's the SMCII module that shorted out. The module sits in the bottom, outer corner of the housing and if water gets in, that's the first place it pools.
You have a couple options...
You can buy a used module on eBay, etc. Make sure it's from a vehicle from your region ie US vs Germany. LHD vs RHD. You can then code the used module into your car.
You can buy a new module from an oem parts reseller. However, a new module requires flashing, then coding.
You can also edit your VO and remove the option for adaptive lighting. This will remove the error on your dash, but adaptive lighting will not work.
If you are in the North NJ or Philly area, I can do all the necessary flashing/coding for you.
Old 08-04-2013, 07:49 PM
gsxrbb gsxrbb is offline
Mein Auto: 2009 535i, 2010 335ic
Mine flashed this code last Thursday. Its going in to dealer next Saturday. Just to let you know, adaptive lights worked fine the next day no errors.
Old 11-27-2013, 06:45 AM
MirkoPunz MirkoPunz is offline
Send a message via ICQ to MirkoPunz
Mein Auto: 320d touring
fdriller9 please could you explain what do you mean with "You can also edit your VO and remove the option for adaptive lighting. This will remove the error on your dash, but adaptive lighting will not work"? I would like to apply your suggestion (I do actually have the same problem and do not want to spend any more money on the car) to simply remove the message (I don't care if the cornering lights do not work). What's the VO? Thanks a lot.
Old 11-27-2013, 06:55 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
$2k for an early model E9x is not significant.
How can you ever hope to move up to Porsche, or Mercedes, when you are concerned with that amount?
Old 06-19-2014, 10:44 PM
Tstyln Tstyln is offline
Mein Auto: 2006 750i
Any updates on if this issue was resolved? I just bought some new Hella Headlights for my e65 and am getting the same error message. The dealer thinks that maybe the headlights are not adaptive, Hella says they are. I think with a new SMC II module it will work...I hope.
The body shop installed my SMC II on the wrong headlights I think but I'm not sure if there is a right/left or maybe once they are coded it knows it for the right or left.
Any updates here?
Old 06-19-2014, 11:24 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Crap! Where should that duct tape go? I even have Gorilla tape! I used to live in Seattle where moss grows on your roof but now I can't get any moisture in So Cal but what if it actually happens one day? What a horrible design to leave such an expensive part exposed to water. I'm not hurting but still wouldn't want to spend $2k to fix that stupid thing!
Old 09-11-2016, 07:35 AM
applejack applejack is offline
Mein Auto: 135i
How do I go about deactivating my adaptive Corning.
