Old 07-27-2013, 04:25 PM
moejav moejav is offline
Mein Auto: 13' 328i-loanr, 07' 335xi
2nd bimmerfest post - Need 335d Help/Advice
Hey All!! I hope everyone is having a better weekend than I.
I have an 07' BMW 335xi that my wife drives which led me to buy the 2009 335d. I bought it from KG Motors in Mason Ohio I drove it to a friend who works near by at a garage, and is a VW guy but has scan tool and can scan BMW's. The car has a clean carfax!! He told me it would need some brakes in the near future but otherwise looked like a great deal at $19,750.00 and below KBB and NADA. So I bought it. Less than 24 hours later (yesterday morning), the reduce engine power icon came on as well as service engine soon. I take it to the bmw dealership this morning and the intake is clogged and perhaps the cylinder head with carbon. The dealer used a scope with camera and the intake was so clogged they couldn't see in to the cylinder head for carbon. Can the intake be cleaned versus replaced like the dealership is saying? Any way of preventing this in the future with an EGR Delete kit or something?? I"m looking at $1800 to replace the intake and if necessary, $4000+ to pull the head and dip it, and then put it back in. I bought the car in Ohio and don't get 72 hrs. it was bought AS IS Any help or advice would be greatly appreciated!! Thank you!!
Old 07-28-2013, 07:24 AM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
I have never done it - but word is that BMW, MINI & others are using walnut blasting. Yes, walnut blasting - check out utube videos for MINI on the subject. BMWOEM1 first posted about the process - I couldn't believe it either.
Old 07-28-2013, 08:07 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Odd they can't blast it. Costing me, what, <$200 to do mine including reusable parts, 335i. 'Course I already had a compressor + shop vac.
Have you looked through a diesel forum?
EDIT: Here's the expensive BMW setup - I'm using what's in the link above
Name:	BMW Walnut Shell Blaster (Wezag).jpg
Click to enlarge
Old 07-28-2013, 08:09 AM
Oh, and the guy w/scan tool? Don't go back.
Old 07-28-2013, 08:37 AM
floydarogers's Avatar
Pedant and Curmudgeon
There's been a bit of discussion on walnut blasting in the diesel forum, and on the e90post diesel engine forum lately.
Walnut blasting doesn't seem to be an appropriate and doable method of cleaning the intake/head on diesel engines, the reason being that the intake manifold has a swirl flap in it that prevents access by a blaster nozzle. There's also a bend at the intersection of the manifold and head.
The only way to do it is to remove the manifold. Not sure if the manifold can be cleaned once off, and if the intake can be blasted once manifold removed.
EGR delete is being discussed, but it requires changes to the DDE (ECU) because it's monitored as part of the emissions equipment. There is also concern that EGR delete might toast the PDF because of the higher exhaust temps- it's a $2500 part. Note that the recall changed many EGRs and re-programmed the DDE to hopefully solve this problem - many people (me included) have not had problems; I'm at 70K.
http://www.bimmerfest.com/forums/sho...d.php?t=708494
http://www.e90post.com/forums/showthread.php?t=796278
Old 07-28-2013, 06:47 PM
I've been looking for the diesel forum, but can't find it. Thank you for your help
Old 07-28-2013, 06:59 PM
My last reply, the first link is in the diesel forum. Once you click it, click on the forum home link at the top.
Old 07-29-2013, 04:46 AM
Thanks Floyd, just noticed you're in Washington. I was just in Seattle and Poulsbo, WA a few weeks ago. It's beautiful out there!!
335d, carbon build up, cylinder head, intake manifold
