Old 09-23-2013, 04:33 PM
ou18 ou18 is offline
Playing Mechanic At Home
Send a message via AIM to ou18 Send a message via Yahoo to ou18
Mein Auto: 1997 740 IL
Re: Mission accomplished
Tonights sngine ******..valve covers back on
Sent from my SGH-I777 using BimmerApp mobile app
ID:	398427   Click image for larger version
ID:	398428   Click image for larger version
1997 Black 740IL (w\ badass Phone in console)
Old 09-23-2013, 04:43 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
Really getting there...you should be very proud!
Old 09-23-2013, 05:16 PM
Like i keep saying.once she is back and i turn the key and it doesnt leak or blow up..ill be proud.lol
Old 09-23-2013, 08:13 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
thats the best part is hearing the engine humm again then the bleeding process begins...Once thats over and no leaks its the bomb
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 09-24-2013, 04:45 AM
Faboch or Jitsjaf,
can one of you snap a pic of your oil lines to the engine mounting bracket. I think i have them reversed. Want to make sure they are on correctly from the oil cannister to the mounting bracket.
I thought i had a good pic of them before i pulled them from the bracket but i dont...
Old 09-24-2013, 09:31 AM
FABOCH's Avatar
only 1 i have i think...its tuff to take a pic down there
This was my friends rebuilt engine going in a 2001 740i sport
Old 09-24-2013, 10:00 AM
Appreciate the pic...thanks
Old 09-24-2013, 04:08 PM
ebida3's Avatar
ebida3 ebida3 is offline
Society of the 7's East
Mein Auto: 2001 740iL
Crossover tube question
The metal tube that runs in front of the water-pump, where does it go under the l/s of the motor?. I seem to have an exhaust leak there but it under the motor kinda behind the alt.I do see 1 bolt but how does it affix?
Old 09-24-2013, 04:37 PM
More pics..belt tensioner on and alternator back on..
Old 09-24-2013, 04:38 PM
Ebida..i do not have a metal tube jn front of my water pump...did u check realoem for ur model year?
Old 09-25-2013, 04:03 PM
What do think..painted the headers witb some black hi temp paint..it will rub off im sure.but looks nice now...
Old 09-25-2013, 04:26 PM
Intake back on....oh yeah....
Old 09-27-2013, 12:17 PM
Not much more I can do on the actual engine until its back in the car.
Gotta get my tab on the tranny mount welded after I cracked it.
Drive Shaft goes to shop for center bearing replacement . 57.50 to have that done.
So this weekend is engine compartment cleaning weekend. and shrink tube some exposed wires in there.
This ought to be a dirty weekend with the car. LOL
Pics to follow...
Old 09-27-2013, 03:21 PM
FABOCH's Avatar
99-01 have a secondary airline pipe made of alluminum...It is held by 1- 10mm bolt on either side...Its tuff to get to..Fan shroud, move the expansion tank to the side with the hose connected(so u dont have to loose coolant there)
Disconnect #8...Leave the end of the hose connected to the Alt ON
You must also remove the fan off the fan clutch or unless u have a fan clutch removal tool then do that... Remove the upper radiator hose...You`ll lose coolant so refilling and bleeding is imperative... Then remove the 2= 10mm bolts...Then the pip POPS off...the ends of the PIPe is held into the engine block with O-rings...They are prolly shot...if so replace the o-rings..or do what I did...To make sure I had no more leaks I USED RTV on the ends of the pipe and popped the pipe back on with the 2- 10mm bolts...My codes went away as well as the exhaust type smell inside my cabin ..Gone was the ENGINE Service light too
The codes assocciated with secondary airline LEAKS are P1492 and P1491...any other codes ur digging in the wrong location....On side NOTE the exhaust headers Bolts Do come LOOSE over time...tighten them....Might be an easy fix but getting to all exhaust header bolts are a SOB
Old 09-28-2013, 11:57 AM
A little prelim fitting on the drive belt..put the radiator hoses on.being ill be loading this baby thru front end of the car.not in thru top....power steering pump mounted and new hoses installed..new ps pulley as well installed..realized i had the wp pulley mounted wrong.flipped that around..cleaned the ribs of the harmonic balancer with wire brush..lots of caked in rubber in there..all cleaned up.ps pump is degreased and cleaned up.. Engine bay has been prelim degreased..gotta hit it again..redid some cladding on a few wires that were exposed...fairly productive day...
ID:	399302   Click image for larger version
Old 09-28-2013, 12:42 PM
A little more...ps lines in engine bay installed...
Old 09-28-2013, 01:14 PM
FABOCH's Avatar
Black headers looks good but for perforance sake , since u have it out still., WRAP those babies up with some headers wrap....Keeps the engine bay cooler
Old 09-28-2013, 01:41 PM
I know its tough to tell from the pics but the engine bay is degreased
First is before. Second after
ID:	399307   Click image for larger version
Old 09-28-2013, 04:31 PM
Thanks faboch...i had thought about that..may run and get some tommorow..is it tlreally a noticeable difference..
Old 09-28-2013, 06:09 PM
ebida3's Avatar
Faboch, I cranked down on the right side bolt. That was the one I loosened erroneously while removing the water pump. The leak all but went away. But it's still there. No codes and with windows up, you do not hear it. But the only leak point has got to be the o-ring in the l?s tube. I guess once I finally get tired of the leak, I'll just have to remove it. But for now, at least for this week the windows are up and the stereo is a-rockin'!
Thanx you.
Old 10-14-2013, 10:24 AM
Well, transmission is at the office. Mobile welder is coming out to fix the busted mounting tab for me. Gonna see if he can tack weld a nut on the filler screw for the tranny.Apparently the torx grooves are stripped out.. So it would be nice to get into the tranny to fill it. LOL...
We'll see what he says...
Old 10-15-2013, 07:20 AM
Transmission tab welded back on...one step.closer to getting this beast back together and running..
Old 10-15-2013, 11:09 AM
Crom! Crom! is offline
Mein Auto: 2014 328i & 2000 ML320
Was the welder able to fix the stripped out grooves?
Old 10-15-2013, 11:27 AM
No. He tried welding on some aluminum and loosening the plug.but it didnt work..so im gonna have to drill it out..gonna take the pan off and do it..this shld be interesting..
He tried left handed bits first..its in there pretty good..
HTML code is Off
