E36 (1991 - 1999)
Old 07-28-2013, 11:31 AM
Ron 52 Ron 52 is offline
Mein Auto: BMW 3 and 5Series
Question Oil in my radiator
i seem to have oil oil in my 318i 1998 radiator , but there is no sign of water entering the engine like you would get from a blown head gasget is there a link between the oil and water cooling systems that could cause this proplem. the car is running very well with no water from the exhaust or excessive pressure in the radiator. can anyone point me in the right direction. thanks Ron
Old 07-28-2013, 11:36 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Is it a lot of oil or just a few globules floating in the expansion tank?
Old 07-28-2013, 01:03 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
pics??
auto?? could be trans cooler....check the trans fluid....
df
Old 07-28-2013, 01:07 PM
hornhospital's Avatar
D'oh, You Kids!
That'd be pretty odd, since the trans fluid and engine coolant are circulated in two different radiators. Although the trans cooler is bolted to the radiator, there's no interchange of fluids.
Quotes to live by:
Old 07-28-2013, 11:48 PM
Thanks for your replies, its just a few globules of emulsified oil around the filler cap .it could be head gasget paranoia I owned a citreon but only once. oil on the dip stick looks OK and seems to maintain its level. I think i will get the car up on the ramps and have a look at the transfluid although it looks to be a seperate system to me?
Old 07-29-2013, 03:41 AM
Burning2nd's Avatar
Under the lift arms
its fine leave it be
15486372<-----
Old 07-29-2013, 06:58 AM
D'oh, You Kids!
It IS a separate system. There's no way for the trans fluid and coolant to co-mingle.
Quotes to live by:
Old 07-29-2013, 07:15 AM
Burning2nd's Avatar
Under the lift arms
Just a little bit won't hurt anything , probably do you some good
Probably picked it up when te fluid was dropped in to a pan and then reused
If you have a lot of lot of oil ... U have problems
15486372<-----
Old 07-29-2013, 08:52 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
I fail to see how oil mixing with coolant could "probably do you some good"
While, its not good that its in there, I would flush the coolant, and see if it returns. If so, check compression on all cylinders, as this could be a breached headgasket leaving oil in the coolant.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 07-29-2013, 08:24 PM
have a manual, so i was guessing on this based upon many other radiators that i have worked on that were (other than bmw) auto equipped cars........
df
Old 07-30-2013, 09:45 AM
D'oh, You Kids!
Yup, many auto-trans cars have a heat exchanger for the trans fluid that is within the radiator. If it leaks, you get trans fluid in the coolant. My Blazer is like that. If the blasted thing ever goes again, I at least know the system is good, since I'd just replaced the radiator (with integral trans oil cooler) before the brake booster when kaflooey. It turned into a money pit when it got to 250k miles. Lurch has lurched to a halt.
Quotes to live by:
