E36 (1991 - 1999)
Old 07-28-2013, 03:01 PM
Todd Molland Todd Molland is offline
Mein Auto: 1995 BMWM3
E36 Is it the Climate control Unit or something else
Recently my 1995 M3 started blowing heat on the drivers side and AC on the passenger side from only the defroster and floor settings. Everything is normal from the middle vents so I don't expect that it's an AC issue. When I use just heat all seems fine too. I suspect it's the climate control unit but I thought I would try to get some input from an expert on the Forum.
I think the problem started around the same time I changed the cabin micro filter but not sure.
Thanks for the help in advance.
Todd
Old 07-28-2013, 03:23 PM
jbomz3's Avatar
jbomz3 jbomz3 is offline
Mein Auto: 323 convertible
Hiya, if you've got dual zone clmate control and both sides are set to the same low temperature but 1 side blows hot I think it's a sign the heater valve in the engine compartment is faulty. It's up against the bulkhead/firewall.
http://www.realoem.com/bmw/showparts...26&hg=64&fg=18
Cheers J.
Originally Posted by PhilipWOT View Post
Yeah, our M3's are a bit watered down under the hood too.
Old 07-28-2013, 06:34 PM
Hello Jbomz3,
The heat works fine though. Both left and right are normal. Do you still think its a heat valve?
Thank you
Old 07-28-2013, 07:29 PM
jbomz3's Avatar
Yes, if you set your climate control inside your car to the lowest temperature on both sides but 1 side is cool and the other side is hot the side that isn't cooling isn't shutting off.
If the climate control is set to the highest highest temperature and 1 side gets hot and the other side stays cool then the valve on the cool side is stuck shut.
The valve has coils of copper wire inside and on my drivers side the copper wire had broken so wasn't shutting the water off no matter what my climate control was set to my drivers side got hot as the engine warmed up, but the passenger side was working as it should.
Cheers J.
Old 07-29-2013, 06:25 AM
You have convinced me. I found the heater valves. How in the world do I service them. They look very hard to get to with a wrench? Thank you so much for the help.
Todd
Old 07-29-2013, 10:23 AM
jbomz3's Avatar
Hope this helps.
http://www.pelicanparts.com/bmw/tech...e-Cleaning.htm
Cheers J.
