E36 (1991 - 1999)
Old 07-28-2013, 07:24 PM
outlander108 outlander108 is offline
Mein Auto: bmw 325IS E36
94 325is- E36 help with vacuum hose name?
Hi guys !
I need help identifying the name of the hose that I am pointing to with a screw driver in the picture and probably the function if possible.
I was checking my hoses today and found out that the hose at the bottom was damaged...I just put a plastic hose until tomorrow.
thanks for your help...
ID:	388903   Click image for larger version
Old 07-28-2013, 10:19 PM
PCV Valve Breather hose...
found out the name of it " PCV Valve Breather hose" but will a rupture in bottom hose cause hesitation on acceleration?
Old 07-29-2013, 05:49 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Yes. ANY vacuum leak will adversely affect the running. It introduces unmetered air into the system. The ECU meters fuel according to how much air it thinks is going into the engine. With a vacuum leak the engine runs lean, since the air/fuel ratio is off.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
