E36 (1991 - 1999)
Old 07-28-2013, 10:38 PM
Ominahan Ominahan is offline
Mein Auto: 1994 BMW 318ci
Question '94 BMW 318ci starting issues
When turning the key to start my car in the mornings it seems to be having problems. In the mornings it takes 4-10 times for it to actually start but after that it usually starts the first time the entire day until the next morning. I have put 93 octane fuel and seafoam in it and that seemed to get it to start in 4 times at the most. I was thinking of putting gas treatment in it to see if that would do anything but im afraid it may be the fuel pump.Thanks for any help
Old 07-28-2013, 11:24 PM
outlander108 outlander108 is offline
Mein Auto: bmw 325IS E36
could be anything at this point: ignition problem or fuel system problem.
start with the easy stuff: check your spark plugs, battery terminals, fuel filter...if all good then your next guess are bad started, ignition wires, fuel injectors and fuel pump.
is the check engine on? do you have any codes?
I don't think fuel treatment will hurt at this point.
Old 07-28-2013, 11:52 PM
Well ill try the gas treatment. Everything else is fine, but ill take a look into the fuel pump and fuel injectors.
bmw 3 series convertible, help advice needed, starting problems
