Old 07-28-2013, 10:41 PM
BMW4Lee's Avatar
BMW4Lee BMW4Lee is offline
Mein Auto: 2008 335i convertible
Question Plastic/Chemical odor inside car
I know my car is close to 6 years old and I donít expect the interior to have that new BMW smell anymore, but it has a plastic/chemical odor to it. It is more pronounced when I run the air. I brought it to the dealer and they told me that there isnít a problem with the car, but it may be the all-weather (rubber) mats that I have inside. I took the mats out, but the odor is still there.
If anyone has insight into this issue, it would be appreciated. Thanks in advance for your assistance.
2008 335i convertible | Sparkling Graphite | Black Leather | Dark Burl | Sport | Premium | Steptronic | Navigation | Comfort Access | PDC | HD Radio | iPod |
ED Pickup Date: 11/2/07
Departed Bremerhaven: 11/13/07 on the Hojin
Arrived at Port Hueneme: 12/6/07
Cleared customs: 12/14/07
Redelivery: 12/17/07
Old 07-29-2013, 01:51 PM
BMW4Lee's Avatar
I went to the dealer today and was told that it is mildew building up on the condenser (or something like that) and that I need to do an a/c service for $285. I passed on the service for now. I am not sure how mildew can have a chemical-like smell though. The SA did say running the heat will dry it up, but I don't get much chance to use heat in the summer here.
Old 07-29-2013, 02:01 PM
///M-Furby's Avatar
///M-Furby ///M-Furby is online now
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
Why don't you turn your car on (at home), and let it run with the heater on? Come back 20-30 minutes later
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 07-29-2013, 03:38 PM
BMW4Lee's Avatar
Not a bad idea. When I get it back from the dealer for my ongoing brake pedal issue, I will try that. Thanks for the suggestion.
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
How about turning the AC on full bore, then spraying tons of Lysol into the air intake to kill the mildew?
Perhaps followed by Febreze to make it smell purdy.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 07-29-2013, 03:58 PM
swampX3 swampX3 is online now
Mein Auto: bmw++many
clean air act
here in the swamp the rubber/plastic mats sweat a great deal.....they can get very pongy......good to take them out for a few days and let the undersides air/dry out.....we also spray the back of them with lysol or jomax
same products for the air ducts .....gotta get a good running fan and all windows open on the car .......slip out the air filter and let er rip .....it will need to gas off for a good few hours.....we've seen the jomax and bleach trick kill dense mildew/black mold ....be very careful to keep it from blowing onto sensitive interior surfaces .....we cover the vents with red rags
Old 07-29-2013, 04:04 PM
BMW4Lee's Avatar
It's weird because it doesn't smell musty or like mildew, but perhaps I don't know what mildew smells like. I suppose I just need to take the dealer's word that it is mildew
Old 07-29-2013, 05:05 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
As BMW specifically recommends against idling the car, I'd opt for driving it with the heat on instead. Lower the top, put the fan on minimum and aim the small amount of heated air that comes out at the windshield.
Tom
Old 07-29-2013, 05:15 PM
BMW4Lee's Avatar
I did not know that. Thank you for your input.
Tom
Old 07-29-2013, 06:04 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
You have the standard E9x "gym sock / barnyard / Yeti foot syndrome.
Three things you can do:
1) when parked, be sure to set the recirc to "off"; this allows the condensate to drain better, according to my SA.
2) 10 minutes out from home, switch off the AC. This allows dry air to pass over the coils, drying them, inhibiting fungus growth.
If neither of the above work, I heartily recommend this product, applied specifically according to the instructions:
http://www.amazon.com/automotive/dp/B0002Z2MKO
"Klima-Cleaner is a professional air conditioner cleaner that effectively removes odors caused by mold, fungus, pollen, nicotine and dust. While other products mask odors, Klima-Cleaner uses active foam to directly clean and remove odor causing agents from the evaporator core of the air conditioner system for fresh and clean air that lasts for months. For best results, apply every 3-6 months. Klima-Cleaner is water-based and does not contain any harsh chemicals. Caution: Recommended for professional application only. On certain vehicle makes, damage may occur if product is not applied properly. If uncertain about application, have a certified mechanic apply product. In some cases, a screen behind the air vents may prevent tube from being inserted. Check vents with a flashlight to see if there is a screen. If any of these cases apply to you, we suggest you use einszett 911104 Klima-Cleaner Easy-To-Use (ETU)."
This stuff really works, I've used it on my E92 and it completely eliminated my odor problem.
Old 07-29-2013, 07:55 PM
Otherbmw Otherbmw is offline
How long have you owned the car? Did the odor start recently or has it been there a while? My 335 cab has always had a strong plastic/chemical-like odor. I've always believed it is from the leather and plastics in the car as I have smelled it in other BMWs.
Old 07-29-2013, 08:44 PM
BMW4Lee's Avatar
It doesn't smell like that though. It really is more of a plastic/chemical-like odor that is stronger when the A/C is on. Perhaps the reason my car still smells like that when the car is off is because after I turn off the A/C and the car, it sits closed up in a garage for a week or so (it is not my daily driver). Can mildew smell like plastic or chemicals?
I have owned the car since it was new (close to six years). The odor started a few years ago, but has gotten worse. When the dealership took me home today in a new X5, I thought to myself, "That is what my car used to smell like."
Old 07-30-2013, 07:03 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Your evaporator core is starting to leak.. When the AC stops working that will confirm it.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 07-30-2013, 07:23 AM
BMW4Lee's Avatar
Would I notice any leaks under the car? The dealer tells me it is mildew, so I don't think they will investigate it as an evaporator core leak without some other evidence.
Old 07-31-2013, 07:44 AM
David1's Avatar
You will not see a leak. You can go to napa and ask to smell the refrigerant oil used in 134ac. If it is what you are smelling in the car, evaporator has a pinhole leak.
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 07-31-2013, 10:39 AM
Hm ya that does not sound like fungus.
Have you taken it to a good Indy AC shop?
ďCharacter is doing the right thing when nobodyís looking. There are too many people who think that the only thing thatís right is to get by, and the only thing thatís wrong is to get caught.Ē
- J.C. Watts Jr.
Old 07-31-2013, 10:44 AM
David1's Avatar
Many times, the leak is so small that the refrigerant sniffer/detectors will not pick it up. even if you have a dye in the system, you cant get to the core to look for a leak.
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 07-31-2013, 02:00 PM
BMW4Lee's Avatar
If that is the case, I don't have much of a chance of getting the dealer to do anything about it. Additionally, I have read that the whole dashboard needs to be removed to get to the evaporator core
Old 07-31-2013, 02:32 PM
David1's Avatar
That would be true for most cars today.
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 10-18-2014, 06:49 AM
weezl weezl is offline
Mein Auto: 535i 6M
What was the outcome of the odor issue?
-Weezl
  • '13 335i Blk/Blk;6M/ZSP/ZPP/ZDH/CWP/NAV/CA/PDC (no ED )
  • ED#2 9-1-11: '11 535i Blk/Blk; 6M/Sport/Prem/ZDH/CWP/NAV/CA/fold-downs/PDC; Dropoff Paris, redelivery So Cal 10-21-11;gave back 2 BMW
  • ED#1 9-1-08: '08 535i Blk/Blk; 6M/Sport/Prem/CWP/NAV/CA/fold-downs; RETIRED (just gave it back to BMW).
  • '02 330 CiC, 5M/ZSP/ZPP/heated seats/Bi-Xenons/2-tone leather, DE-BADGED; Lease buyout @28K (62% resid), SOLD Ď08 @ 36% MSRP after 7 years/60K miles. Great 1st BMW!
Old 10-18-2014, 08:00 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is online now
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Can be any number of bio agents floatin' around in Summer air. There's a fog of bacteria & fungi at ground level, and plenty of food - just add water. Enter: Your AC condensor! Drippin' with life-giving dihyrogen oxide, the liquid snags both organisms and tasty food; provides medium for growth.
Good Bimmerfesters DIY clean with Lysol, or quaternary amine, then maybe enjoy the waft of Potpourri, a treat for the senses! 'Which scents to sniff?' you say....I'm glad you asked....what's your pleasure?
But wait...WAIT...what if it's THIS?!?!?!
Name:	Monkey BIG [25].jpg
Hang on. Is this thread, like, OLD?
Old 10-18-2014, 09:01 AM
BMW4Lee's Avatar
The issue has surfaced again and I have been posting on another thread, but I will update here as well.
I have been experiencing a plastic/rubber type smell -- almost like Band-Aids -- coming out of my vents for close to 2 years now. The smell is faint when you get in the car, but when you turn on the A/C and put your face to the vent, it is quite strong. I have no problem with the cooling or volume. When I have brought the car in in the past, I have been told various things: no leaks, mildew, floor mats, etc. -- basically no resolution. I don't drive the car often (it is a 2008 with 15,000 miles), so the A/C is used infrequently.
Last week, they did something called a "Wynn" treatment (fog-like treatment for the vents) as well as changing the cabin filter. The treatment only masked the smell -- I could still smell it, but it was mixed with the treatment smell. The other day, I drove the car with the A/C on and it gave me a headache.
At first they did not want to do any additional testing, but armed with another thread from Bimmerfest [http://www.bimmerfest.com/forums/sho....php?t=736924], they contacted the factory representative again. They decided to do further testing as the preliminary tests did not find a leak. Unfortunately, further testing requires removal of the dashboard to get to the evaporator. I was told that even if a leak is not found, they are going to replace the evaporator under warranty.
While I was there, I was speaking to the technician working on my car. He let me smell some used evaporator oil that was evacuated from another car. It was a very strong, chemical-like smell. I couldn't say that it was exactly what I am smelling in my car, but that may be because it was so concentrated and mine is diffused through my vents.
I really hope this solves the problem because I don't know what other options I will have after the evaporator replacement.
Old 10-20-2014, 06:23 PM
BMW4Lee's Avatar
I got the car back today. I was told that oil had leaked from the evaporator. The evaporator was replaced and the case was cleaned. My car smells like a BMW again.
