Old 07-29-2013, 09:13 AM
Bigrob126's Avatar
Bigrob126 Bigrob126 is offline
Mein Auto: 2010 328i Coupe Auto
Brake Q
I've noticed if I stop rather hard, when I let off the brakes pedal, the car kinda jerks forward a little. Like instead of the calipers opening up gradually,they pop open....releasing the car! This is also with the AC on, and idle is a little higher. Doesn't alway happen. I saw a thread about why not to purchase the car. The OP mentioned driving in traffic and coasting issues. Not sure if it was related to what I am describing.
Rob
Old 07-29-2013, 09:16 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Do you hear a slight creak when you come to the stop, also when you let off to go (like when the light turns green)?
Could be worn rotors/pads.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 07-29-2013, 10:08 AM
Bigrob126's Avatar
I don't believe so. If I did hear that creak, what would it be?
Rob
Old 07-30-2013, 01:05 AM
Drooper Drooper is offline
Mein Auto: E90 E60
When you get this sound it's rather late to replace the pads - they are gone and will damage your rotors so that you have to replace both for sure. But check your rotors if you see worn scratches like small groves that's a clear sign
Old 07-30-2013, 03:58 AM
Banned
Mein Auto: 2007-335 HTC
I believe what the OP is saying is that when he takes his foot off the brake peddle that his brakes are still applied for less than a second and they release, My car does the same thing. I figured it was a safety function for what ever reason, I just ignore it.
and I just replace my brake pads and noticed nothing wrong with the rotors, and cleaned the brake calipers and greased the pins, so I know its not a caliper, rotor or pad issue. Most likely a brake programing thing within the car.
Old 07-30-2013, 07:39 AM
Bigrob126's Avatar
Definitely not a wear issue. I'm a car guy and would be all over that. Rotors are fine and pads have a lot of life. It rarely happens. Yesterday not once. Ya know, we have had a lot of humidity here in Vegas the last week or so. It is finally drying out. Could be the humid air causing the pads to be sticky in a sense. Anyway, the car is still under warranty, so if need be, I will see my friendly dealer.
Rob
