Old 07-29-2013, 03:46 PM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
Longer crank times and high idle
About two months ago I began noticing a couple of unusual symptoms.
First I noticed longer crank times in the mornings. They weren't overly long, but longer than usual. Sometimes it seemed like the engine was trying to start, but would stutter and start on the next turn. Once the engine was running everything was fine, no shaking, or misfiring, and no codes at all, at least according to my Cobb AP. Also, if I restarted the engine right after running it, it would start on half a turn, but if the car sat overnight, or for several hours, it would take it longer to start.
Second thing I noticed is higher than usual idle RPM. Once warmed up, my car has always idled around 650 RPM with AC off, but lately I have noticed that once fully warmed up, it idles at 850 RPM. What is strange, is that for the first 20 minutes or so of my drive it idles fine at 650, and the idle jumps up to 850 only AFTER it's fully warmed up and the oil temp reaches 240F or so.
Also, in the past when the AC was turned on, the idle RPM would rise to about 750, which is normal with an added load on the engine, but now, when it's idling at 850 and I turn on the AC, the idle RPM doesn't go up any higher, and I feel a slight vibration, as if the RPMs are too low.
The only mods I have are FMIC, DCI and Cobb flash. I unmarried Cobb from my car and restored it to stock PPK, but there is no difference. And still no codes or errors of any kind.
I took the car to my dealership, since it's still under factory warranty. They've now had the car for 5 days and haven't been able to find anything wrong, or at least that's what the SA told me. For the long crank issue, they for some reason they replaced the starter on the car.
I don't know how good of a diagnostic they performed, but they told me that because I have an aftermarket air filter (aFe DCI), they cannot go any further since the high idle is probably caused by the DCI, and if I want them to do more, I'd have to pay for it...
Did I mention that it's a 2010 car with 38k miles with factory warranty??? And since when does an aftermarket air filter that's been used by thousands of people cause these kinds of issues??? I called BS on that, but they won't budge. And I don't know what to do. I called BMW NA and the idiot on the phone told me that since BMW dealerships are private enterprises, they have the right to refuse to do work under warranty!!!
ARGH!!!!
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 07-29-2013, 04:23 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
So, you're restoring your intake to stock?
Old 07-29-2013, 04:26 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
+1,
I'd return the whole thing to stock and find another dealership.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 07-29-2013, 05:46 PM
Originally Posted by thekurgan View Post
+1,
Yes I am. They didn't notice the Cobb FMIC, and I didn't say anything either, but the stock airbox is going back in. I already have an appointment this Thursday at another dealership.
I was kinda hoping someone could tell me if they've experienced or heard of these issues and what the possible causes could be.
Previous BMWs:
