REMOVED VANOS no special tools - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 07-29-2013, 07:05 PM
JayMac JayMac is offline
Mein Auto: 01 M3, 83 320is, 75 2002
If you need to remove your vanos and do not have access to the special tool needed to do this you can do what I did. Unbolt everything as needed. Tap the vanos a few times with a rubber mallet or a piece of wood to wake it up. On mine you could see it start to separate from the head. The BMW tool rotates the exhaust gear not the cam. The chain turns the vanos gear clockwise (backwards). So what need to do is move the chain in a clockwise direction. I did not want to scratch the chain or damage any of the gears so I needed to come up with a way to do it without the needed tools. I took a piece of covered wire. It was from a busted trailer brake away system. I looped it through a link in the chain, wrapped the bitter end around a piece of wood overlapping the cable so it will bind on itself when you pull on it. A little tug on the cable/wire and a tap with the mallet and the vanos was off in my hands in a second.
Works on exactly the same principle.
Old 07-30-2013, 08:53 PM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Cool trick bro!
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 07-30-2013, 09:44 PM
Woodacre tom Woodacre tom is offline
Mein Auto: 330 rag 328i
looks like a good way to do this. I had a problem getting the cam travel correct resulting in a p1519 code. I had to go back in and re- time the cams. What I learned was this: Take the exaust cam bolts out when you rotate the cams clockwise as this will fully rotate the intake cam. When the vanos pulls in the gears must all move at the same time. Watch this Utube vid and pay attention @ 19:26 when the cam gear moves and the vanos does not. This is a very key bit of information and will screw you up.
Good luck
Old 07-31-2013, 05:44 AM
I agree. I was watching the same video and had to go back and forth a few times. The key is the gear moves but the cam does not. You can't see it in my shots but the e torx on the exhaust cam are out. Bottom line is if you have access to the tools that is a big help but you do not need them in order to remove the vanos. I was parting out this engine so it was never going back together. I needed a way to get the unit off and the special tool moves just the chain which in the end is all I did. I would add that the chain only moves about a link in order to pop the vanos.
Old 07-31-2013, 05:50 AM
The point at which you reference is because he did not have the vanos lined up properly. He does a great job of explaining that. I think he makes a note to make sure they seat together.
