Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 07-30-2013, 06:14 PM
jg183 jg183 is offline
Mein Auto: 87 535i
Question 88 BMW 535i HELP ! trans light flashes rough starting .
Hi , my name is James and I realy love my 88 BMW 5 series. Im haveing problems with it tho and was wondering if anybody has heard these symptoms before .
1. Crankes for a long time , starting only after 2 or 3 or maybe 4 attempts to crank her over. 2. Trans light flashes ( randomely) when it sputters durring starts and after starting and this corresponds to the rough idle. The engine misses as it flashes. Dosent miss when it dosent flash 3. after starting the engine revs and fluctuates several hundred RPM but does not stick at a high RPM and die. 4. Sputters and sometimes dies when I give it gas from a stop but runs fine after I get her rolling. Im sure somebody in here has heard of these symptoms before , I mean theres only so many things that could cause this to happen right ???? Anybody ???
Old 07-30-2013, 08:51 PM
catso's Avatar
catso catso is offline
catso
Yes, it could be alot of things. I'd start with the ignition system; plugs, wires, coil, cap, rotor, sensors, etc, then I'd carefully examine all the vacuum hoses, and the idle control valve. The fuel injection system would be on my list after that. Get yourself a Bentley repair manual and it may help you diagnose your problems.
![/I][/FONT]
Old 07-31-2013, 10:20 AM
Mein Auto: 87 535i
88 BMW 535i
Im going to check the ide air first. I should probly do the plugs but I think theyre in good shape. I could probly use to replace the vaccum hoses tho. I recently replaced the computer with 1 out of a 635 and switched the chips. Im thinking it may be the TCM but Im not sure. I have the OBD system completely bypassed so I cant retrieve error codes. The OBD is not functioning and keeps the car from starting so I went around it. It didn't give me any trouble this morning exept for hard starting without the trans light flashing so it must be an electrical circuit or brain box or valve or sensor thats malfunctioning or failing.
Old 08-01-2013, 11:22 AM
Mein Auto: 87 535i
found something.
I went over my fuse box and found a loose and melted 25 amp heater blower fuse. I replaced it and my car dosent sputter or die and idles solid for the most part. It is doing it a little but Im thinking that this fuse is loose or maybe there was some heat damage in there somewhere. ! thoing I know for sure is that after changing that fuse the car behaves much better. Its still hard to start when its cold only tho. After its warmed up it starts by the second crank. Not perfect but Im still rollin.
Old 08-01-2013, 04:50 PM
catso's Avatar
catso
Electrical problems can affect almost everything on these cars.
![/I][/FONT]
Old 08-02-2013, 11:06 AM
Mein Auto: 87 535i
the fix
I was a quart and a half low on oil because of a small leak. Need to fix that. Anyway , I took out 710 ml of tranney fluid and replaced it with 710 ml of lucas trans slip fixer. I also added a quart of oil with a can of engine restore. The car starts right up now from sitting cold all night and dosent sputter when I hit the gas in 1st gear. I hope this adds to somebody elses diagnostic work in the future.
Old 08-02-2013, 02:45 PM
catso's Avatar
catso
You best bet is to not use additives. Change your trans fluid and filter and use a quality synthetic fluid.
![/I][/FONT]
HTML code is Off
