Old 08-01-2013, 06:14 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
E46 Space saver on E9x
Can E46 Space saver fit onto E90
as most E90 rims can fit E46
Can anyone shed some light ????
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 08-01-2013, 06:30 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
I recently acquired a "space saver" spare for my E93. It's a very narrow 17" wheel setup. Based on that if it works on a stock E93, it should work on a stock E90/91/92 as well.
Bought mine from ECS Tuning. ~$450 (Wheel, Tire, Tools, Cover, Shipping)
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 08-01-2013, 08:17 PM
SilverX3's Avatar
did you buy a E46 Space saver ?
Job - Captain
MY11.5 X1 Xdrive25i
Old 08-01-2013, 08:27 PM
Nordic_Kat's Avatar
Not specifically. Here in the US, vendors are marketing a compact spare that will fit E9X cars. It's a 17" rim, Conti tire. It's very narrow relative to our normal tires. Don't hold me to this dimension, but 215 rings a bell. Bottom line, it can be stowed well in the Cabrio with room to still stuff a few things on top and then lower the partition that allows top down driving. If it works in the trunk for an E93 it will be sure thing in an E90 or E92.
Old 08-01-2013, 09:09 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
its a 125 or 135 /80 depending on if its the E46 or E60 spare-- very narrow.
the E46 compact spare will fit, but you will need a 15-20mm spacer for brake clearance depending on model
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 08-01-2013, 09:28 PM
Nordic_Kat's Avatar
LOL, 215 - 125 Dyslexia is a wonderful thing.
So, Orient, now that your bring this up, does the wheel that is marketed as an E9X "space saver" (125/80/17) also need the 15-20mm spacer?
Old 08-02-2013, 05:36 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
And I presume the "current" lug bolts (length) would be OK?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 08-03-2013, 05:02 AM
The E60 based spare does not. the offset is 8 (iirc, the E46 one is 20-25) so it clears the brakes on even the 335i no problem.
side note, it doesnt clear the front brakes on an F30 335i. you need a 10mm spacer for that car.
Old 08-03-2013, 05:04 AM
nope, you need to get longer lugs.
i got a 15mm hubcentric spacer, and 5 bolts of the correct length for about $40 total so i could use my E60 based spare on my F30.
Old 08-03-2013, 03:06 PM
SilverX3's Avatar
apparently this could work on e46 space saver on e90
Job - Captain
MY11.5 X1 Xdrive25i
Old 11-05-2013, 09:40 AM
Iammiro Iammiro is offline
Mein Auto: BMW 335i convert.
I just checked on their web site it is almost $520 with shipping, I did not realize inflation is so high. Kat, how do you like your kit, everything OK., no spacer needed, have you use it already or tried it. Need one for my wife 2010 E93. She has already gone through her rear 313 19", both were cracked, shredded one of her rear RFT. Now she is having new set of 18" 313 with non RFT Michelins. Would like your opinion on the spare set and if you like it, I am sure she will too. Thanks, Miro
Old 11-05-2013, 10:44 AM
ecs is overpriced for some things
http://www.getbmwparts.com/partlocat...catalogid=4462
365 shipped
Old 11-05-2013, 11:54 AM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
365 shipped
No offense to Tischer, I will blame BMW engineering. I would throw that jack off a bridge into a deep river. Get the X5 scissor type. It is much safer and fits the E90 jack points. I have 3 of them. $25 to $35 in local salvage yard.
http://bmwfans.info/parts-catalog/E5...ack#6754372_11
#11 in figure (NOT #2). get the handle too (#12)
Old 11-05-2013, 12:01 PM
Tks,I agree. ECS is scissor type, but their price...on the other hand, nothing better than a happy wife, as I know she would be with ECS set. I have been looking at local junk yard, have not had any luck so far.
Old 11-06-2013, 01:44 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
to OP, the E46 one will not fit, unless you have a spacer on it, the E60 one will bolt right on, which we would recommend.
We have some pictures and video of it on our website. you can take a look
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 11-06-2013, 12:09 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
Here is another point of view.... We carry a full size spare wheel and tire behind the passenger seat. It's in a black bag so not an eyesore and on rare occasions when we need that seat for a passenger I'll throw the spare into the trunk.
I went this way because we tour a lot with our car and there are many places where the tire sizes required are not available. In addition if we are booked for a ferry crossing or important hotel night I want to be able to continue the journey at highway speed for as long as necessary. It was the only practical solution for our tour of Newfoundland for example.
The trunk well is perfect for storing jack, wrenches and chocks as well as a small compressor and can of sealant for those times when a nail puncture can be sealed near home.
It would be nice if BMW had made room for a full sized spare but we have been able to cope on those long trips when risk needs to be mitigated.
It's a solution for your consideration if you really need to carry a spare tire.
Don
328XiT Sonora
