E46 (1999 - 2006)
Old 08-02-2013, 08:15 AM
BigMotherWheels BigMotherWheels is offline
Mein Auto: 06 325ci Coupe ZSP
headlights again
I need advice:
I have a 2006 325ci with BMW Dynamic Xenons - they automatically level and turn left and right in response to steering. These "facelift"lights, as many know, have the main lens glued on with a rubbery sealant and therefore do not simply come off.
When a xenon bulb was replaced at a body shop I guess the technician was a bit too rough and broke the projector unit from the servo that moves it left and right. I don't want to pursue that with them - I certainly cannot prove their wrongness. I just want it fixed. I am very mechanically apt and think that if I could access the area under the projector then I could remake what ever part is broken and fix it myself.
This is what I need advice on - I have read and seen examples of folks removing all electronics and baking the light at 250 degrees F until the sealant is soft enough to let go and remove the lens that way. Is this worth it? Has anyone tried it or seen it in person? What is the risk of destroying the unit and having to buy a $900 unit replacement new or take a risk on a used one.
Old 08-02-2013, 08:37 AM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
The headlights on my brothers Subaru Legacy are similar in that they are glued together with the sealant. He needed to take them apart but was hesitant to stick them in the oven, so he used a heat gun and slowly worked his way around the edge with a butter knife to get them apart. I witnessed it, and while it was a slow process it worked like a charm.
Old 08-02-2013, 02:47 PM
JayKayo's Avatar
JayKayo JayKayo is offline
The UltimatE46 Enthusiast
Mein Auto: 2005 330Ci ZHP
Baking them in the oven is exactly how I got my headlights apart to install the angel eyes.
A hair dryer was used the second time they were taken apart, but by then the factory glue/sealant was gone and we used some other material - silicone or something.
Old 08-03-2013, 06:55 PM
headlights again
Thanks for the input. I might just give it a try.
Old 08-03-2013, 09:54 PM
JayKayo's Avatar
Just one word of advice, don't leave ANY cracks or openings once you re-seal them up after you're done doing what you need to do. The slightest passageway will cause the inside of your lens to fog up when you get a wash.
