Changing headlight on 88 5 Series - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-02-2013, 05:57 PM
Easyrhino Easyrhino is offline
Mein Auto: 1988 535is
Is it possible or does the car need to be shipped back to Munich? I can't figure out how to get the #%$ bulb out.
Any help offered is greatly appreciated.
Thanks,
ER
Old 08-02-2013, 07:00 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
If you have a US model, you first need to remove the black front grills (small black plastic screws in the clips. Once the grills are off, you will see three small screws holding the metal surrounds for the headlights. There are also plastic covers for the back of the lamps that are removed from the engine compartment after you raise the hood.
See section 63: http://www.bmwtechinfo.com/repair/main/137en/index.htm
Old 08-02-2013, 09:21 PM
catso's Avatar
catso catso is offline
catso
Once you remove the plastic grill, it only requires removing three small screws that hold the headlight retainer ring. It's really quite easy.
![/I][/FONT]
HTML code is Off
