Old 08-02-2013, 06:17 PM
retro1302 retro1302 is offline
Mein Auto: 1999 328i / 2013 X3
Shifting to neutral
Hypothetically. You break down. Tow truck comes. Engine does not start. Car is in park. How do you shift to neutral if you can't start the engine?
Old 08-02-2013, 06:38 PM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
Typically, you don't. You have your X3 winched onto a flatbed, cringing the entire time. I can pretty much guarantee you that whomever is providing BMW Roadside Assistance in your area knows nothing about the procedure for forcing your X3 into Neutral.
Got power? Engine cranks but doesn't start? I haven't tried it because I've never been in a condition where my engine won't start, but this is the alleged procedure:
1. Depress brake pedal
2. Press start stop button...engine won't start but will crank
3. Press shifter release button on side of shifter and hold it
4. Move shifter forward one step-hold it there for 2 secs....exactly
5. Release side switch and repeat. N should be displayed in instrument panel...trans unlocks
Got no power, engine won't crank? Now it becomes a bit of a problem.
Got a wheel chock, a jack, a jack pad, and a jack stand? Got tools? If not, you don't have a way to safely shift into neutral.
Old 08-02-2013, 06:53 PM
Unbelievable. I've never seen car company complicate the obvious as BMW does. All I wanted to do was push the X3 a few inches forward, without starting, in order to get my lawn tractor out of the garage. Wow.
No spare, no oil dipstick. that stupid auto shut off at the traffic light. Yeah, save some gas but wear but wear out the starter. I miss my old Jeep.
Thanks for the reply.
Old 08-02-2013, 07:02 PM
Anfänger Anfänger is offline
_________________
Mein Auto: 2013 X3 35i
All the sordid details are available in the F25 Powertrain technical training document (sect. 3.4 Transmission emergency release)
Old 08-02-2013, 07:03 PM
Thanks. I'll check i
Old 08-02-2013, 08:11 PM
WHITEX's Avatar
WHITEX WHITEX is offline
On our 2nd Alpine X
Mein Auto: 06 X3/2010 MCSC
Yep...but we love our X's. Miss my Wranglers.
GONE>>>Sold. One of the best rides I ever owned. My 1st BMW-2006 X3 3.0 White w/blk. Prem/Nav/Sirius/Servo/Heated seats,steering/Park Dist./Xenon/Privacy.I got the auto. trans. so my wife can drive it.
Our 2nd Bimmer2014 X3 i35 Alpine/Chestnut. Nav,Prem,Tech,Cold Weather, Shades. Got the Automatic cause we had no choice
My 1st Mini-2010 PW, I got the 6 speed so my wife can't drive it. Laurel Edition Convert
Old 08-04-2013, 05:14 AM
poker838 poker838 is offline
Mein Auto: F25 x28 n52 + n20 / B8 A4
In a few years I'm sure more manufacturers will be the same. I've never read about people complaining on the Benz forums but their shifters are electronic and column mounted...
Lincoln has recently introduced a transmission that uses buttons mounted on the dash... Jaguar is on their rising knob thing... I think my next vehicle will be manual transmission not for performance but for maintenance...
Old 08-04-2013, 06:09 AM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
If the car is towed because it is not parked in an acceptable or legal place and it was left in Park with the emergency brake on, will the transmission be damaged? Is there a concern if it is winched onto a flatbed?
Old 08-04-2013, 06:10 AM
slambmw slambmw is offline
Mein Auto: x3
Shifting to neutral
BMW is too damn complicated and expensive, but the vehicles do drive so well.
Old 08-04-2013, 06:56 AM
The X Men The X Men is offline
Almost all shifters are electronic now, or at least they do not have a direct mechanical link to the transmission like the old days. The problem with BMW's shifter is that the mechanical shift lock release is under the car, not somewhere that is easily accessible like it should be.
Old 08-08-2013, 09:23 PM
04prox2 04prox2 is offline
Mein Auto: x3
[QUOTE=02420X3;7749592]Typically, you don't. You have your X3 winched onto a flatbed, cringing the entire time. I can pretty much guarantee you that whomever is providing BMW Roadside Assistance in your area knows nothing about the procedure for forcing your X3 into Neutral.
tried several times doesn't work. The only way for sure is to jack car up crawl under, there is a silver bolt on the side of tranny you screw it upwards, it pushes a lever up and puts tranny in neutral, I have personally tried this and it works. The older x5's had a cable attached witch you could activate in the rear compartment. Was going to build similar device but it takes a lot of effort to push up lever.
