Old 08-02-2013, 06:58 PM
CajinMom CajinMom is offline
Mein Auto: 328i convertible
2009 328i Hard Top Convert problem
Hello all, 1st post on here, but hoping you all can help. My 328i convertible is misbehaving. Out of warrenty with around 50K on the miles. Raise and lower the top daily so heavy user. Yesterday, go to put the top down, the windows lower, and the roof unlocks. You can see the front panel slip up a little. Then it just stops! I mean the whole thing just goes dead. Checked as much as I can see in the truck for an bloackage or non-seating lid. All that looks good. Since it starts to lower, figure the fuses are good, but checked for any blown fuses and found none. I am guessing I have a bad relay somewhere or a bad motor. DOn;'t know how to diagnose this nor do I even know where the motor for the top is located. Any advice is greatly appreciated.
P.S. I also have the frayed lines as well that I have read about on here. Black outer covering gone, but white lines still intact.
CajinMom
Old 08-02-2013, 08:03 PM
fun2drive's Avatar
BMWCCA 149159
More than likely it is a misadjusted microswitch that is causing this. Best advice is to get someone that can read the codes because there are codes stored for a malfunction like this. Also (I have a 2007) The dealer has an updated string kit which should according to those that have it installed (Kat for one) state it wears really well. I would get the codes read to help identify the actual problem and and have the dealer replace the stings even though it will not be cheap the string kit will be done right.
Old 08-02-2013, 08:06 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
I've never worked on one but here is some liturature:
http://project-a8.info/parts/bmw+ssp...520Hardtop.pdf
http://prodcds.bmwuniversity.com/lib...20Card_web.pdf
Old 08-02-2013, 08:22 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
CajinMom
>AHEM<
*COUGH*
Old 08-02-2013, 08:33 PM
Originally Posted by A B Able Truck View Post
EXCELLENT info, A B....THX!!
OP please note the Salmon Relays.
Old 08-03-2013, 05:49 AM
Thaks for the info. Will let you all know what we find.
Old 08-03-2013, 07:56 AM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
This sounds remarkably similar to when the right cowl hinge had to be replaced on my car back in 2011. This was done as a known issue, and although I don't have the SIB # for it, IIRC my SA did indicate there was an SIB associated. With regard to my top cords, I also had these replaced in 2011. Like yours, my car is an '09, although it is still under warranty - at least for a couple more weeks.
Good luck with the fix and keep us posted.
ps: Welcome to the 'Fest!
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 08-03-2013, 05:18 PM
Relay it is !!
So, after you all give me a few hints, off i go to locate and shake those salmon relays. All I did was pull them out, lightly clean the contats, then reinstalled them. VOILA! Working now. So, will oder two relays and replace those currently installed with the thinking they might be going bad. Special thanks to AB and CALWATERBOY. Appreciate you guys.
Old 08-03-2013, 05:45 PM
Yes! Always good to help a guy willin' to work....
Old 08-03-2013, 05:55 PM
Keepittrill's Avatar
Keepittrill Keepittrill is offline
My avatar is a selfie LOL
Mein Auto: 2011 M3 DCT
You raise and lower the top daily? LOLwtf why?
2010 E89 Z4- gone and forgotten (;
2011 M3 DCT
'14 C7 Z51 3LT M7
20 and blessed.
Old 08-04-2013, 06:06 AM
If you drive an E93, you know.
Old 08-04-2013, 11:19 AM
I drive a Z4, so it's pretty much the same thing.
2011 M3 DCT
'14 C7 Z51 3LT M7
20 and blessed.
Old 08-04-2013, 04:49 PM
Submariner Submariner is offline
Mein Auto: 328i Monaco Blue 'vert
From an E93 user - thank you. May I kindly suggest you post this in the sticky post about 'tip-top condition' for the E93?
Old 08-04-2013, 05:04 PM
Nordic_Kat's Avatar
Excellent Idea!
Old 08-04-2013, 07:13 PM
I don't know how to sticky - but go ahead if you know how.
Old 08-11-2013, 02:05 PM
Update: Installed two new relays from Pelican Parts, #12-63-1-742-690-BOE "Relay Changer Salmon Red, Brand: Genuine BMW" at $13.25 a piece. Popped the new ones in and working great thus far with about 15 cycles. Again, thanks for the help. Really appreciate you guys chiming in.
