motion sensor location - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 08-03-2013, 06:47 PM
melkmike melkmike is offline
Mein Auto: 2005 320i executive
hi,
I just bought a 2005 bmw 320i and was planning to install the oem alarm system. The problem is that i dont know whre to install the motion. Most of the models have that cover on the ceiling, but mine is different.
thnx
Old 08-03-2013, 09:07 PM
JayKayo's Avatar
JayKayo JayKayo is offline
The UltimatE46 Enthusiast
Mein Auto: 2005 330Ci ZHP
Well then, are you asking for suggestions as to where to put it?
Because mine's exactly where you said it is, on the ceiling. That's really the optimal place to put it since it covers the most surface area in the car.
Old 08-04-2013, 08:52 AM
Mein Auto: '06 AW 330xi
Center dome light. Pull it down, there should be a space for the ultrasonic sensor to clip into. You'll also find the plug there to connect the sensor to.
Old 08-04-2013, 08:53 AM
Wait is this an OEM or aftermarket alarm?
Old 08-19-2013, 05:29 PM
It's an oem alarm. Mine e46 doesn't have that dome light in the center
