E46 (1999 - 2006)
Old 08-04-2013, 06:08 AM
THIRD3SERIES THIRD3SERIES is offline
Mein Auto: 2000 323I
thought it was a idler pulley
noise in area of fan on my 2000 323i , replaced idler pulley, still there, any thoughts?
Old 08-04-2013, 07:14 AM
Tommy D Tommy D is offline
Mein Auto: '05 BMW 330i
Replace the Tensioner and or pulley next. If not then go after the AC tensioner/pulley. Could be your alternator bearing , maybe the water pump. Did you replace the belts?
'05 BMW 330i - 126,000 miles
'87 Ford Mustang LX 5.0L Hatchback - 248,000 miles
'98 Ford Taurus SE DOHC - 115,000 miles
'05 Mazda Tribute s AWD - 117,000 miles
Old 08-04-2013, 07:43 AM
next i am going to remove serpentime belt, and check pulleys
Old 08-04-2013, 11:01 AM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
If you replaced one pulley, you should have done them all at the same time
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 08-05-2013, 08:27 AM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Use a stethoscope (If you have a Harbor Freight about $10)
Old 08-05-2013, 08:46 AM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
^^^^ This.... and this is a job where you should definitely use OEM parts. I tried to save a few dollars by using after market pulleys when I did my cooling system refresh and my pulleys started squealing again after only ~8,000 miles. Lesson learned.
Old 08-05-2013, 11:26 AM
wdaveweaver wdaveweaver is offline
Send a message via MSN to wdaveweaver Send a message via Yahoo to wdaveweaver
Mein Auto: 2004 330i ZHP
+1 - I thought I had a bad WP recently, when it turned out to be a bad bering in the Fan Clutch. Found out real quick once I touched the probe to the WP that it wasn't the one making noise. Diagnosed it by pulling the fan and starting the car. Instantly found my issue.
Gig'Em Ags
Old 08-10-2013, 10:52 PM
chilangolalo19 chilangolalo19 is offline
Mein Auto: 2000 328I
if you replace one pulley you should replace all of them along with belts
