E46 (1999 - 2006)
Old 08-04-2013, 04:13 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Timing Chain Tensioner Spring DIY
So I was inspired by BlueBee and Doru and their discussion found here....http://www.bimmerfest.com/forums/sho....php?p=6169504
My ZHP has 189k miles on it now and I figured I'd do mine. I have already done Beisan seals and the rattle fix, but what could it hurt? And the parts only cost me $5.00.
The original post shows an E39, however the E46 is obviously identical and the tensioner spring is in the same spot. Funny how all these years working on these things and I NEVER noticed that little hump under the check valve on the head.
All I did was remove my windshield washer fluid reservoir for added clearance and used my 1/2 breaker bar with a normal sized 32mm socket (my deep well one was too big). Once the initial hold is broken, it is easily unscrewable with your hands. I was surprised that my spring was as compressed over time as it was. It would appear slightly more worn down than the one from the OP. I replaced it, put the new copper washer on it, and tightened it to 70nm. Started the car and checked for leaks. None to be seen.
All in all it took me 20 minutes. I wish I could say I was rewarded with noticeable improvements, but for my car (which idled quietly and drives just fine) there were none. Nothing but a satisfaction of another small maintenance item that could POTENTIALLY help me avoid disaster some day when buzzing around at 6800rpm.
This is no harder than replacing an oil filter so don't fret, just do it!
ID:	389774   Click image for larger version
ID:	389775   Click image for larger version
ID:	389776   Click image for larger version
ID:	389777   Click image for larger version
Old 08-04-2013, 06:35 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
I should do this too. 197,000 miles.
Old 08-04-2013, 09:11 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Old 08-05-2013, 10:10 AM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Humm doesn't seem to difficult and not a bad idea to change it out. Maybe I'll do this soon to, thanks for the post!.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 08-05-2013, 10:54 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
I use to replace the timing chains completely with Pete Jackson gear drives back when I used to street race. Timing would jump all over the place after about 10k on a new chain, but was rock steady with the gear drive setup. I don't believe there was a tensioner back then. You just replaced the chain when it became sloppy. I had a few cars that had phenolic sprockets for the chain from the factory. What a joke. There was a thriving business in steel replacement sprockets. Judging by how much smolck's spring fatigued, I think you guys are doing the right thing. Chain flop leading to failure would be catastrophic.
Old 08-05-2013, 02:24 PM
smolck's Avatar
ROLL TIDE!
I had gear drives on my 5.0 mustang race motors. Loved that gear whine!
Old 08-05-2013, 03:30 PM
TheMalibuMafia
Especially in my situation with the type of power and the way I drive my car. I should change it asap. I'll be doing an oil change, oil filter housing gasket, valve cover gasket, PS lines and AFR gauge hookup soon. I'll do this while I do that.
TheMalibuMafia.com
Old 08-05-2013, 03:38 PM
SJBimmer's Avatar
Does make everyone look, that's for sure. Then they ruined it by making a non whining version! I don't imagine they sold too many of them. Can't sell if you don't advertise! Great mod though.
