E46 (1999 - 2006)
Old 08-04-2013, 07:03 PM
Claudia325CI Claudia325CI is offline
Mein Auto: 2002 325CI
Rain causing electrical issues with my 325ci, any recommendations
I got caught in a freak rainstorm today with the roof down, by the time I got the roof up there was a lot of rain that had entered the car. On the drive home the horn started going off on it's own, I removed the fuse for it a onto used home. Once at home all the lights stayed on after stopping the car. I then proceeded to disconnecting the battery and used a blow dryer to try and dry the dashboard components, I now have a fan running in the car to dry it out as well.
any recommendations as to what else I can do and what could be the potential damage this may have caused?
Thanks,
Pierre
Old 08-05-2013, 05:26 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
It sounds like the steering column still had water in there- horn n key switch. Dry out is the way to go. Might have to disassemble some of the column but give it a little time first with the fan etc.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 08-05-2013, 05:53 AM
Thank you I will continue the drying process and hope for the best.
Old 08-05-2013, 09:40 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
If you have access to a garage, I would try putting it in there and either rent or borrow a dehumidifier. I have one in my basement, and it makes this otherwise damp area completely dry. If that is not possible, go to your local big box store, and buy a couple of containers of damp rid. It is a moisture absorbing substance. Put it in a pan or such to prevent possible spillage on the passenger and driver side floor, close the car up, and let it work. You will be amazed by the amount of moisture it collects. Good luck, from a fellow Vert owner!
Old 08-13-2013, 12:23 PM
Gray993C4 Gray993C4 is offline
Stan
Mein Auto: 1998 328IC
HMMMMM water leaks are pretty hard to identify. It's just a matter of trial and error - first identify where the water is coming from generally. Then start investigating rubber seals and body sealer lines. Sometimes the rubber seals can dry out, crack, and shrink, allowing water to enter. Has your car ever had body work in the area of the leak? That's always a good place to start since many shops are pretty sloppy in the way they seal body panels.
Old 08-13-2013, 01:15 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Reading Is Fundamental, Sparky....
The OP describes being caught in a torrential downpour with the convertible top down....
(You must have missed that part, eh ? )
The road goes ever onward....
(R.I.P. Jever)
Old 08-13-2013, 01:16 PM
Stan
Hahaha oops - do much for multi tasking
electrical problems, rain
