Finally fixed my transmission on my 91 525i. - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 08-04-2013, 08:38 PM
Photojunky Photojunky is offline
Mein Auto: 1991 525i
I kept on getting the trans program warning light after the car was warmed up then the car would not shift out of 3rd gear so I took it to my local shop which is normally very good and fair. I told them from everything I had read I thought it was the TRANSMISSION speed sensor or band apply solenoid. So the dummies changed the speed sensor located on the axle and not the transmission speed sensor. So then they changed it back and told me the code said it was the kick down switch. I told them I didn't think so but told them to do it since they were only going to charge me 164. When I got the car back after 15 mins of driving the problem started up. I brought it back but this time they told me they were going to send it to their transmission guy who owned a shop and did all their tranny work. To make a long story short he said the tranny was bad and needed to be replaced. I said BS. I got my car back and changed the band apply solenoid like I told them in the first place and so far the problem seems to have gone away. I'll keep my fingers crossed.
Old 08-05-2013, 12:49 PM
Mein Auto: 1989 525i M20B25
Yay!
Old 09-09-2013, 05:26 PM
55bmw 55bmw is offline
Mein Auto: 1992 525i
band apply solenoid?
What and where is the band apply solenoid?
I have similar problem and replaced the transmission speed sensor, no help.
Oh, I'm very new here
Hi
Old 09-09-2013, 07:52 PM
Remove your transmission fluid pan, then your transmission filter. Then towards the rear of the pan you will see a small solonoid with a wire going to it and a pin holding it in. Remove the electrical carefully, mine was brittle, then remove the pin. It is an easy job but messy because you will be draining fluid. Pm me the result if you do it.
This is what it looks like. http://www.amazon.com/4L30E-Transmis.../dp/B00CBFMXG6
Old 09-09-2013, 07:55 PM
And what is it? From my understanding it downshifts the tranny from 4th and 3rd to 2nd.
Old 09-10-2013, 09:51 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
Nice work!
"Herr Doktor will see you now..."
Old 09-11-2013, 12:51 PM
BMWFatherFigure's Avatar
Old School
The solonoid works the band type brake that stops the gear housing spinning. This 'changes gear'. Only 2 gears involved, not three. Google planet and sun gears and see how it works.
Current:
E38 Parts Car
Previous:
Old 09-12-2013, 09:32 PM
justaseatacguy justaseatacguy is offline
Mein Auto: 91 525I
Not sure if I am hurting anything or not, but when my transmission program light comes on, I just stop, turn the car off for 10 seconds, restart and the light goes out and everything is "normal" until the next times. Transmission Program light comes on sporadically (maybe two times a week, sometimes longer).
Old 09-13-2013, 06:14 AM
Mine was doing exactly that but it was also locking in third gear. I'd turn it off and wait a couple then it would work for a while. If you've never changed your transmission fluid I start there. Can't hurt.
Old 09-17-2013, 07:10 PM
Milliesdad Milliesdad is offline
Mein Auto: 525i E39 Touring
random trans program notification
lots of electronic reasons this could be :-)
may just be spades on connectors and relays - the gear selector connection under the panel around the gearstick down to the solenoids on the exterior and in the box having bad connections
(if your box goes ping anytime it may be the gear selector or gate button on the stick, or the sport economy button connectors/relays or on the trail from the throttle and gear control to the ECM from under bonnet to trans - usually down the trans end connectors between the ECM and trans- even worth cleaning the relays under the bonnet by the fuses and in the passenger side wall or behind glove) the 3rd gear one a bit more serious to look at as protection mode is always worth getting a computer plugged in for fault codes - and more likely damaging if you persist with
Old 09-18-2013, 06:18 AM
According to the shop mine was giving the wrong code, I can't remember what they told me. The transmission shop they sent it to said the same thing. So I looked up the problem on the Internet and also looked up the specific transmission also used in many other vehicles and started with the easiest and cheapest issues and got lucky.
Old 09-18-2013, 08:40 AM
I am goint to try the band apply solenoid next.
Here is what i've done so far:
replaced gear shifter thing under the console, electrical about 3" long and 1/2" wide
replaced trans speed sensor
relaced fluid, filter
it is running a bit warm so i'm going to replace thermostat, water pump
oh, also my auxiliary fan does not work, so replacing that too
that should cool things down a bit, i know heat is the enemy to engine and tranny
any help getting good prices on any of the above mentioned would be appreciated
Old 02-17-2014, 12:07 PM
it worked
I finally got it installed, after 4 weeks and no problems, it's fixed :-) :-) :-) :-) :-) :-) :-)
Old 02-17-2014, 12:21 PM
was it the band solenoid?
Old 02-17-2014, 02:20 PM
Yes
Yes it was, the low band solenoid, cost about $80 on eBay.
It is just under the trans filter.
Glenn
Old 05-23-2014, 07:26 AM
Angry i'm back
Well, it's been a few months and it started to happen again, just as bad. I replased a lot of cooling issues, no help. Could the solenoid have gone bad again? Maybe the wires going to it? I'm at a loss.Aaaarrrggg!!!
Old 05-23-2014, 08:56 AM
My transmission finally went as well, and the horn stopped working, and the headlights stopped working, and the stereo, and the air bag light... I sold that piece of junk for $600 bucks. It was the first BMW I owned that fell apart like that. Oh well.
