E46 (1999 - 2006)
Old 08-05-2013, 09:24 AM
eddym eddym is offline
Mein Auto: 2006 330i convertible
jammed storage compartment
wife put a lot of loose change in storage compartment above ashtray compartment and now it won't open any ideas?
Old 08-05-2013, 09:56 AM
lgr122 lgr122 is offline
Mein Auto: '00 e46 M43, '05 e87 M47
You mean this kind?
Old 08-05-2013, 10:17 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Try a small screwdriver and see if you can pry it open, gently of course.
Old 08-05-2013, 11:45 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Maybe this ^.
Or It may be that several coins have lined up perfectly to prevent you from pushing in on the door. Next time you're in a parking lot with speed bumps, hit one a little harder than normal and jab repeatedly at the little door handle at the same time. Or maybe while going over a railroad crossing or similar bumps. Thinking you have to knock the change/crap loose in there (upward) to provide the space needed for the release to happen.
Worst case scenario you could take that whole assembly out (a few screws, 12v socket power connector and button connectors if I recall) and shake it/turn upside down while trying to open.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 08-05-2013, 08:46 PM
mofunk mofunk is offline
Mein Auto: 2004 325ci
PUsh it while pulling it. It's not that hard. omg how much change did she put in that thing. I've only had it get stuck when the AUX cable get hung up in it.
