Headlight help!!!! - Bimmerfest - BMW Forums
Old 08-06-2013, 12:01 PM
Tottiar13 Tottiar13 is offline
Mein Auto: 2006 325i
Headlight help!!!!
I installed a pair of after market headlights on my 2006 325i, xenon and eagle eye. For some reason the left light refuses to turn on, I made sure everything works on it by installing the left headlight on the right side, and it's turns on perfectly. Idk what is wrong with my car. The right headlight works perfectly fine, but the left one refuses to turn on. Please help me figure out what's wrong. Thank you guys so much in advance
Old 08-06-2013, 12:06 PM
Mein Auto: '06 AW 330xi
You had halogens originally? You need to code your car for xenon. Add option code $522 to your VO and code CAS and N/FRM.
Go to coding section for more help.
Old 08-06-2013, 12:14 PM
Yes I had halogens originally, I have had xenons before, and they worked fine till water got into one and it stopped working, so I figured I would change both. Could it be an electrical problem? Fuses are fine and the left light works fine too when placed on the right side. I have no idea about coding. But I know my last pair of xenons worked fine.
Old 08-06-2013, 05:22 PM
3SJetblack's Avatar
3SJetblack 3SJetblack is offline
Mein Auto: 2013 E92 M3 ZCP
Headlight help!!!!
If water killed the other light, probably an electrical issue. Did you try your old left light in the right side to see if it worked?
Old 08-06-2013, 05:30 PM
You can find someone in your area to code for you. You can also have them code the bulb error off so you don't have to mess with error cancelers.
Old 08-08-2013, 03:21 PM
Headlight help!!!!
Still can't get it fixed, and I can't seem to find anyone who can code, I live in Maryland, Rockville, any help?
