E36 (1991 - 1999)
Old 11-16-2013, 06:27 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Eh, maybe. People run plastic fans without any clutch whatsoever in many other applications outside the world of BMWs.
1998 BMW 328is
1966 Pontiac GTO
Old 11-16-2013, 06:38 PM
dwonda's Avatar
dwonda dwonda is offline
Insane in the membrane!
Mein Auto: 1996 328iS
Yes and people that do this usually run into problems from the increased stress to the fan. Simply put a fan designed to run on a clutch is NOT designed to be run without the clutch. There are however fans that ARE made to be run without a clutch, which are flex fans and others. If you ever get the chance why don't you try locking your clutch and see how long your fan lasts.
I find it a little amusing that everyone is so quick to believe and accept that the fan blades break from just being old, but if I want to throw in the variable of a locked fan clutch, its just ridiculous. Did you even bother going through the threads I posted earlier?
Old 11-16-2013, 08:14 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
I went through them. That said, the reasons the fans break on BMW's are threefold.
1. Heat cycles.
2. Age.
3. stress.
In that order.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 11-16-2013, 09:20 PM
dwonda's Avatar
That doesn't make any sense, if a clutch was locked on a brand new car, obviously the mechanical stress will break the fan before heat cycles and age.
Old 11-17-2013, 05:13 AM
jonesin's Avatar
The Canadian Prick.
It makes complete sense when you factor in that the fan clutches on these cars is known for failing by becoming weak, NOT by locking.
In fact, until the articles you posted, I had never once heard of a fan clutch locking. (On these cars.)
Old 11-17-2013, 07:39 AM
dwonda's Avatar
Right, but your above statement didn't specify E36. Obviously its more of a problem with the 5 series, considering all the pictures on the net relate to that, so perhaps they DO use a different fan clutch, even though they use the same fan.
Old 11-17-2013, 07:58 AM
jonesin's Avatar
The Canadian Prick.
This thread being in the E36 subsection precludes the need to state E36 on each and every statement made in this forum though doesn't it?
Old 11-17-2013, 08:17 AM
ZeGerman's Avatar
Warm Leatherette
And I would imagine that, like the fans themselves, the clutches are the same unit across many BMW models from that time period.
1998 BMW 328is
1966 Pontiac GTO
Old 11-17-2013, 08:21 AM
dwonda's Avatar
Ok so what is the explanation here? Why are all the pics on the net, the same body style 5 series?
Old 11-17-2013, 08:22 AM
dwonda's Avatar
Ok so when ZeGerman mentioned that outside the world of BMW's many people don't use fan clutches I should have assumed that he meant outside of E36's right?
Old 11-17-2013, 08:45 AM
ZeGerman's Avatar
Warm Leatherette
Stop arguing. If you want to believe that plastic fans on BMWs don't explode simply due to age, heat, etc., then that's your business. I'll also permit you to believe in the afterlife and alien visitation if you want.
1998 BMW 328is
1966 Pontiac GTO
Old 11-17-2013, 10:45 PM
dwonda's Avatar
I'll believe it, all i wanted to do was point out that there can be other causes. But alas, no one will believe me, and my point is moot. Moving onů..
Old 01-29-2014, 08:54 AM
FlukeyE36 FlukeyE36 is offline
Mein Auto: E36 328i
=[ I read this post a couple months back, and I was going to change the whole lot at the beggining of March as soon as my mk2 gti was back on the road. The irony of it is, I used my 328 to jump the golf for the first time since the engine rebuild, and first time in 2 years, and that's what did it. One on, one off!
=[ moral of the story.... DO NOT POSTPONE THIS PRECAUTION!
Old 01-30-2014, 02:05 PM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
The fluid temperature gauge usually justs pinpoints the problem you don't have to really shut down the car or wait until the engine burns, it usually gives you a warning Not that the engine will burn out.
Old 02-13-2014, 04:35 PM
Mapes328i's Avatar
Mapes328i Mapes328i is offline
Lowlife
Mein Auto: 1998 328i
http://www.achillesmotorsports.com/C...e36coolkit.htm
They have a good cooling overhaul kit I'm buying it in the next couple of weeks
Lowlife philly
Old 02-13-2014, 05:29 PM
dwonda's Avatar
Humf, doesn't look like it includes a fan clutch, I guess that isn't a critical part of the cooling system, and could never be responsible for a fan blowing apart as previously discussed. Can't say I'm a fan of the description which is riddled with fear based mis-information. Like lumping the plastic thermostat housing and plastic impeller into the same sentence and later saying that all E36's came with them. Not all E36's came with a plastic impeller though. And I should buy a new radiator because mine is likely cracked and brittle? I'll be the judge of that thank you very much. Seems like a good price though, and I wouldn't mind having an aluminum thermostat housing.
Hey did you know that you should replace your airbags every 15 years?
Old 02-18-2014, 05:08 PM
Mein Auto: Passat
Getting aluminum on your car parts should not be a big of a deal. DEpending on the parts
Old 02-18-2014, 06:48 PM
jonesin's Avatar
The Canadian Prick.
The early (through 1997 E36s) came with the plastic impeller. The 97-99 E36s came with either a composite impeller or a metal impeller on the water pump. All three are known to fail suddenly causing damage though for different reasons. With the plastic: it shatters, or the shaft bearings fail causing the fan to come into contact with minor things like the hood, engine block, or the radiator.
The later ones be they composite or the metal impellers are known to have the shaft bearings fail causing the fan to come into contact with minor things like the hood, engine block, or the radiator.
See any recurring theme here?
I've not yet heard one case on this forum of an airbag failing causing damage or otherwise.
I've got to ask. Are you high when you write these tidbits? Where did this even come from?
Old 02-18-2014, 06:57 PM
ZeGerman's Avatar
Warm Leatherette
You're welcome to be the judge of that - it's your car, but don't for one second suggest that this thread is predicated on "fear based mis-information". The recommendation to replace cooling system components which contain plastic comes from a widely known and longstanding observed history of E36 BMWs (and others) experiencing catastrophic cooling system failures without showing any signs of imminent failure. You are one of the few who resists the trend to replace these troublesome parts before they fail, and you're completely entitled to that practice. But please, don't foul up this thread by suggesting that it's misinformed. E36 cooling systems DO fail, and often. This thread explains how & why they fail, and what needs to be replaced so that owners can avoid this issue.
Depends on the car.
1998 BMW 328is
1966 Pontiac GTO
Old 02-19-2014, 02:54 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
that is all.
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 02-19-2014, 08:26 PM
dwonda's Avatar
Well maybe one of these days you'll all get through to me. I'd rather do a fan delete and wait for **** to fail and keep an eye on my temperature gauge like I usually do.
That's because they all died ...obviously.
Old 02-23-2014, 09:43 AM
hornman hornman is offline
Mein Auto: '99 328I, '98 328I,
new to me is a 1992 325I with a cooling issue
water pours out the back of motor a non-vanos M50. Do i need to remove the engine to see where the water is coming from or is there and easier way to detect the issue. I'm surer the PO forgot to tigten or put in the correct tubing , but when I go to refill the rtadiator water just pours out the back of motor. please someone direct me to a link that shows where all the tubing runs , or even better a photo or two of the back of a non-vanos m50 . I just need to know what and where I'm looking for.
Thank you
Lee
Old 02-23-2014, 10:03 AM
ZeGerman's Avatar
Warm Leatherette
Welp, you aren't going to know where it's leaking from until you actually look for it. It could be a cracked hose, or it could be a blown freeze plug (not very likely, however). Time to get out a flashlight and a telescoping mirror. You should have your answer in a few minutes.
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2014, 01:22 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Thank you
Lee
There's a plastic hose bib on the back of the cylinder head. Not unusual for that to break off and have coolant flood out the back side. It's item 3 in this diagram.
http://bmwfans.info/parts-catalog/E3...ttached_parts/
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-01-2014, 03:25 AM
thirtysixOs thirtysixOs is offline
Mein Auto: E36 318i Cab
Thanks a lot for this!
318i Daily
bmw, cooling system, e36, overhaul
