E36 Cooling System 101: What you need to know - Page 5 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-02-2014, 05:26 PM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
To Phantom
You know I seen many cars that after looking at alumminum based build parts it's either probably a car thing or people should really consider installing cast iron on some key componets instead of a plastic water pump impeller.
Old 04-02-2014, 06:45 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
...which would be why BMW switched from plastic impellers, to metal, to composite.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 04-02-2014, 06:52 PM
Mein Auto: Passat
Lucky you I don't have that kind of money to invest on a car an overhaul every 160 or so miles should be good enough for me.
Old 04-02-2014, 06:56 PM
jonesin's Avatar
The Canadian Prick.
I have no idea what you said though. Can you translate it please?
Old 04-02-2014, 06:57 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
And yet you drive a VW Passat?
1998 BMW 328is
1966 Pontiac GTO
Old 04-02-2014, 06:58 PM
jonesin's Avatar
The Canadian Prick.
Now Karl... We can't all be former Presidents.
Old 06-10-2014, 09:14 AM
krblasch krblasch is offline
Mein Auto: BMW 323ic
Additional beneficial knowledge
Thanks for the additional information. I flushed and replaced the coolant at 40,000 and 70,000 miles as well as replacing the thermostat on my 1998 323ic thinking I was being proactive; now has 71,000 miles non it. I baby the heck out of it, it's never seen snow and rain very seldom. My wife has to move her traverse out of the garage when the beamer isn't in storage because I garage it 365 days a year.
Old 06-23-2014, 01:02 AM
Kluver318is Kluver318is is offline
Mein Auto:
I found my damn problem. Thank you
Old 06-23-2014, 07:39 AM
Engel12626's Avatar
Engel12626 Engel12626 is offline
Pew Professional
Mein Auto: '95 525iT, '97 328is
What problem? And you're welcome.
-Andy
I am always surprised when I wake up with a hangover, and am still able to log in
Old 07-14-2014, 09:14 PM
petenice petenice is offline
Mein Auto:
I just posted a question about my coolant issues i shouldve looked deeper great topic thanx
Old 07-30-2014, 02:57 PM
Mein Auto:
So my car has been in the damn shop all day to replace the water pump and the thermostat and they havent been able to get the fan off WTF!!
Old 07-30-2014, 02:58 PM
dwonda's Avatar
dwonda dwonda is online now
Insane in the membrane!
Mein Auto: 1996 328iS
Sounds like they don't have the right tools...
............_____\_(+)_/_____
Andrew /|O| [||||][||||] |O|\
1996 328iS OEM Frankenstein
Old 07-30-2014, 03:32 PM
Engel12626's Avatar
Pew Professional
My last fan clutch I couldn't get off. I didn't realize I was turning it the wrong way at first, and was tightening the **** out of it
Ended up cracking the water pump puley trying to get it off. But I was replacing the clutch, pulley, and pump anyway so I just unbolted the pump and threw the whole assembly away.
-Andy
Old 07-30-2014, 03:39 PM
Mein Auto:
The guy i bought it from told them its reverse thread, im sure they dont have the tool for the two bolts but they should have 32mm.ill be calling there in the am. Its time ti buy my own tools start doing my own repairs
Old 08-01-2014, 07:31 PM
Mein Auto:
Water pump, thermostat and thermostat are all replaced and new no visable leaks oil is good but coolant level keeps going low any thoughts?
Old 08-01-2014, 07:32 PM
Mein Auto:
(Thermostat housing)
Old 08-01-2014, 07:43 PM
ZeGerman's Avatar
Warm Leatherette
If those items were just replaced and there are no visible leaks, the coolant could be getting lower as the air works its way to the top. Try topping off the coolant for a few days and see if it stabilizes.
1998 BMW 328is
1966 Pontiac GTO
Old 08-01-2014, 08:01 PM
Mein Auto:
Ive keeping an eye on it, i just got it fixed yesterday so we'll see.Thanx for the imput
Old 08-01-2014, 08:44 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, just keep adding coolant and it will probably level off eventually. Seems to take a few days for me every time I open the system up.
1998 BMW 328is
1966 Pontiac GTO
Old 08-01-2014, 09:43 PM
Mein Auto:
Thanx ZeGerman, i dint know what else it could be this is my bimmer but ive worked on all my other rides myself so im drawing a blank on this
Old 08-07-2014, 01:55 PM
Mein Auto:
So far everthing is workin fine my info center keeps telling me to check my coolent level but it seems to fine so in not sure whats up with that
Old 08-07-2014, 04:13 PM
Engel12626's Avatar
Pew Professional
If the fluid level really is fine, then it's just a bad sensor. Easy and cheap fix. Or bridging the two wires in the connector will keep the message from popping up.
-Andy
ZeGerman's Avatar
Warm Leatherette
You probably need a new coolant level sensor.
1998 BMW 328is
1966 Pontiac GTO
Old 08-07-2014, 05:54 PM
dwonda's Avatar
Funny, I replaced mine in September, and ever sine I put in my new water pump and had to replace some lost coolant, I've been having the same problem I had before which is getting a check coolant level message ONLY when I turn off my car and ONLY sometimes. I'm going to pull the connector to the sensor and make sure the contacts are good tomorrow.
Old 08-07-2014, 08:45 PM
Mein Auto:
Only time i get it is when i turn it off, so it must be the sensor
bmw, cooling system, e36, overhaul
