The X5 SAV Forum
Old 08-07-2013, 12:22 AM
white_lancer white_lancer is offline
Mein Auto: E53 X5 2004 3.0 SPORT
Passenger Door Cenrtal Locking Stopped Working
BMW X5 3.0i Sport 2004 Auto
Hi
My central locking has stopped working on the passenger front door. When I lock the car from the key fob all the other doors and the tailgate lock fine apart from the passenger front door. The same thing happens if I put the key into the drivers door lock and lock the car using the key. Everything else locks apart from the passenger front door.
I can lock the passenger front door by pushing the little button down and then unlock it by pulling on the inside door release handle.
Is there some sort of electrical control module inside the door which may be faulty?
Thanks for your help in advance
E61 2.0D Auto
Old 03-30-2014, 08:30 AM
tiarah2 tiarah2 is offline
Mein Auto:
Did you ever find a solution to this problem? I am having similar issues.
Old 03-30-2014, 12:41 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Likely a bad door lock actuator.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 04-03-2014, 03:00 AM
Yes. do a search on my other posts. I did a write up of the fix. there is also a report on removing the door switch panel to test the door lock using a hot wire. You can buy the door switch module from the internet for around 30 just unplug the old one and plug in the replacement one. Simple.
E61 2.0D Auto
Old 04-03-2014, 03:02 AM
sorry - post was on a different forum.
http://www.xoutpost.com/bmw-sav-foru...e-outside.html
E61 2.0D Auto
