H&R Lowering and wheel spacers - Bimmerfest - BMW Forums
Old 08-10-2013, 10:05 AM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
Just had the car lowered last night and I think it turned out great. I added 10mm spacers to the front and 12mm on the rear.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 08-10-2013, 10:32 AM
SoCal Pete SoCal Pete is offline
Mein Auto: 2010 750I
By far the best looking OEM wheels for the 7!
Old 08-10-2013, 10:37 AM
meyre1 meyre1 is offline
Mein Auto: 2011 750LI ActiveHybrid
Why did you add the spacers? Does it effect the handling?
Old 08-10-2013, 11:02 AM
Snorlax Snorlax is offline
Mein Auto: _
Sweet. Those X Drives really need the lowering.
Old 08-10-2013, 12:02 PM
Jersseven's Avatar
Jersseven Jersseven is offline
Mein Auto: 2012 BMW F02
Looks great ... that's the perfect height. Should have come from the factory that way.
Carbon Black / Saddle Brown / Options: X-drive, M-sport, tech, exec, ACC, nightvision
6WB cluster retrofit / paddle & SAT shifter retrofit / BMS stage 1 tune / Pedal Box / 21" BMW 312 rims / 10mm frt & 12mm rear BMS spacers / LCI taillights / LCI grille / ACS spoiler / 760 exhaust tips & flap delete / Mtec V2 halos / Osram CBI HIDs / active high beam SZL / BMW performance pedals / 6NR retrofit / chrome wrapped with 3M 1080 gloss black vinyl / 20% tint / coded / blacked out calipers
Old 08-10-2013, 02:54 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Like I said, all fitted in perfectly, wheels stance and drop. How's the ride? Any stiffer ?
Old 08-10-2013, 03:42 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
Beautiful Richard... Nice touch!
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 08-10-2013, 04:06 PM
Thanks everyone. The change is subtle, yet at the same time make a big difference over stock
The spacers just push the wheels out closer to the fender the way they should have been from the factory. I don't know why BMW pulls the wheels in like that. Check out the Camaro's, look how nice they look pulled out.
I have not noticed any difference in ride. Maybe it's the Dinan effect,("does it feel fast") but when I first drove it I felt like I was sitting lower even though were only talking an inch.
Old 08-10-2013, 05:18 PM
D.B.V.'s Avatar
D.B.V. D.B.V. is offline
Slower Traffic Move Right
Mein Auto: 2009 750i (F01)
That looks awesome Richard! Makes me look forward to my lowering and spacers!
Old 08-11-2013, 08:17 PM
giovanni618 giovanni618 is offline
Mein Auto: 2011 750Li XDrive
looks nice i did the h&r drop i did 10 mm in front but i used 20mm spacers in the rear ... i can defiantly tell the the difference in the ride
Old 08-12-2013, 07:36 AM
D.B.V.'s Avatar
20mm in the back? Please post pics.
Old 08-12-2013, 09:27 AM
Popoemt's Avatar
Richard, question for ya, do you find yourself scraping curbs at all with being lowered?
2015 750i
2007 G35 (trade-in)
Old 08-12-2013, 10:23 AM
None so far. I do not pull all the way up to parking tie's.
Old 08-12-2013, 02:48 PM
al7oot al7oot is offline
BiMMER4EVER
Mein Auto: 750Li F02
Car look stunning man one question though, I know it's springs in front wheels what about the rear? Is H&R better than Eibach ?
Old 08-12-2013, 08:32 PM
htn htn is offline
Mein Auto: 13 750i
Looks great Richard! Did they have to remove the back seats to do the drop? I just hate to have any collateral damage in the process.
Old 08-13-2013, 04:09 AM
My í13 has air suspension in the back so adjusting rods are installed. No need to remove the back seats. The rear is simple and takes 15-20 minutes. I have no experience with Eibach so canít give you a comparison. It took my mechanic about 3 hours to complete the install.
Old 08-13-2013, 07:21 PM
Mein Auto: _
2009-2012 F01's require rear seats and shelf removed for install of springs
2013 F01's have air rear suspension, so links used and no dis-assembly required of the back seats.
2009-2013 F02 - have air rear suspension, so links used and no dis-assembly required of the back seats.
Old 08-13-2013, 07:42 PM
Harold8785 Harold8785 is offline
Mein Auto: 2013 BMW 750LI
Looks great. I sent you a PM. I need details and prices. Lol..
Old 08-13-2013, 09:54 PM
htn htn is offline
Mein Auto: 13 750i
Richard. Pls do share on parts to buy and approx. cost to install.
TIA.
Old 08-13-2013, 10:03 PM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
^_+1~
Old 08-14-2013, 03:22 AM
I purchased the kit from Turnermotorsports.com.
http://www.turnermotorsport.com/p-12...ive-760li.aspx
H&R Sport Spring Set - F02 750Li xDrive, 760Li
Part #: 28999-6
Lowers 1.6" in Front and 1.5" in Rear
Provides superior ride and maximum lowering
Enhance the look of your vehicle with a reduced fender well gap. H&R Sport Springs lower the vehicle center of gravity and reduce body roll for better handling. The progressive spring rate design provides superb ride quality and comfort. A lower wind resistance signature will make the vehicle more streamlined and improve gas mileage. If you are only looking to improve one part of your vehicle's suspension, you cannot go wrong with installing Sport Springs. Fun to drive, H&R Sport Springs are the number one upgrade for your vehicle. Kit includes 2 front springs and 2 rear regulating rods for the self-leveling system.
This item fits the following BMWs:
2009+ F02 BMW 750Li xDrive with self-leveling
2009+ F02 BMW 760Li with self-leveling
Shipping Dimensions:27x17x8
Shipping Weight:15.00
Price: $327.95 (USD)
I have a buddy that is a mechanic so he installed the kit for $200 and that included alignment.
I purchased the wheel spacers from Burgertuning.com. They run $99 a pair. I have 12mm rear and 10mm front. If I had it to do over, I would have purchased 15mm for the rear and 12mm for the front. Still may pick up a set of 15mm and sell my 10mm. Wherever you purchase spacers, make sure they include the longer bolts. Your stock bolts will be too short.
Old 08-15-2013, 09:19 PM
htn htn is offline
Mein Auto: 13 750i
Much appreciated Richard!
Must be nice to have friends that can hook you up. My local shops here quoted me $700 just to do install.
Old 08-15-2013, 10:25 PM
Mein Auto: _
Man that is a rip off. Best I found was $250 for lowering and $75 for alignment.
For $700 they better polish that rear shelf damn good.
Old 08-16-2013, 05:34 AM
M4XBMW7's Avatar
TTurboFest
Wow l $700 is pretty high. I got quoted by a reputable shop $287 out the door w/o alignment for my 750Li for the same parts Rihard installed, H&R springs and BMS 10MM-F & 12MM-R spacers
Old 08-17-2013, 08:46 PM
ill take some pics and post them
