Old 08-11-2013, 10:11 AM
babo babo is offline
Mein Auto: 06 X3
Android/iPhone with 2006 BMW -music
Is there a way to get either android or iPhone to play music thru speakers of pre-idrive x3 (2006) ?
Did a quick search but most posts are about idrive integration.
Thank you
AZ
Sent from my SGH-T989 using BimmerApp mobile app
Old 08-11-2013, 03:21 PM
ngcreese's Avatar
ngcreese ngcreese is offline
Mein Auto: '11 X3
You could use an Audiovox Mediabridge 1500.
That'll give you Bluetooth audio & handsfree phone, USB/ipod/iphone port, and a headphone aux jack. I've added a mountable usb/aux jack to make a cleaner install.
ID:	391044   Click image for larger version
'11 X3 xDrive35i -- Coded
'07 X3 3.0si -- Coded & Traded
'91 e30 325i -- Sold
BMWCCA Member
Old 08-15-2013, 02:46 PM
Mein Auto: 06 X3
Re: Android/iPhone with 2006 BMW -music
Thank you very much for the information.
I just looked this one up and it runs at ~$200 on amazon.
A bit steep price for plating music for me.
Anything on less expensive side?
Old 08-15-2013, 04:37 PM
x3brian x3brian is offline
Mein Auto: X3
Yes the oem headphone jack runs about $90. It connects to the back of your stereo and provides the aux input that came standard on 07 and up behind the armrest.
Old 08-16-2013, 06:52 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
There are Aux jacks out there cheaper than $90. Here's one on Ebay for $45:
http://www.ebay.com/itm/BMW-Auxiliar...-/350162840213
Just do a search on this part number: 82 11 0 149 390
If you have Nav you'll need a different part number.
Old 08-16-2013, 08:23 AM
Mein Auto: 06 X3
Thank you for the link.
I was thinking maybe I can just use phone audio out to car's aux by a simple 3.5 mm wire?
Get a wire from amazon for $5 or so with two male connectors?
Whats the down side to this?
Old 08-16-2013, 08:27 AM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
We did the wire to the 'Aux in' on our 325i with an MP3 player for long road trips and it worked fine.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 08-16-2013, 09:40 AM
Mein Auto: 06 X3
Cool. I'll try this approach then.
Old 08-16-2013, 10:53 AM
DangermouseX3 DangermouseX3 is offline
Mein Auto: 2007 X3, 2008 X3
If you already have an aux-in socket, then this is the easiest way to go. In my 07, the aux-in is behind the armrest which is a little inconvenient, so I plan to move it up front somewhere. But sound-quality is fine this way.
Radio Shack/Walmart/Target etc all carry this sort of wire. There are mono versions also, so just be careful.
Or you could use something like this, and ditch the wire altogether
http://www.ebay.com/itm/Wireless-AD2...743#vi-content
$17, but again, you still need an aux-in socket to put it in.
Old 08-16-2013, 11:24 AM
Mein Auto: 06 X3
I like this one. Thank you!
Kids, wives and wires are not a stable situation.
Update:
Checked reviews on amazon - doesn't look that good. 25 out of total 80 gave 1star.
The next up the price is $40. I think its too much.
Plus it requires charging - takes 5-6 hours to charge. Considering I see its been used infrequently - I'm sure I'll be forgetting to charge it.
For know I'll stick to wires. I have jack in the arms rest . Let's see how this would work.
Old 08-16-2013, 11:57 AM
ngcreese's Avatar
Mein Auto: '11 X3
Just one heads up. With the samsung galaxy s4, I used to use the head phone to aux plug approach. However, sometimes the phone wouldn't recognize that the audio cable was plugged in.
BMWCCA Member
Old 08-16-2013, 12:14 PM
Mein Auto: 06 X3
I have s2. No plans to change it for next year or so. But thank you.
Old 09-09-2013, 10:53 AM
Mein Auto: 06 X3
I'm one silly monkey - there is no aux in the arm rest..
I was so sure there was one I never actually checked....
Embarrassing feeling to say the least....
Old 01-15-2014, 09:01 AM
Mein Auto: 06 X3
Finally got around to install the AUX. G2 works fine, Iphone 5s doesn't. no idea why.
here is the link to my post http://www.xoutpost.com/bmw-sav-foru...nput-navi.html
Old 01-15-2014, 02:11 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Are you charging the iPhone at the same time? Does sit work if you disconnect the charger? If so, ground loop isolator required.
Old 01-15-2014, 02:59 PM
Mein Auto: 06 X3
Haven't tried charging. Let me check and ill report back
Old 01-16-2014, 09:05 AM
Mein Auto: 06 X3
Well apparently I didnt plug the connector ibto the socket so there was no sound from iphone.
But now both phones work great.
Thank you gentlemen.
Old 01-16-2014, 12:42 PM
spokelizard spokelizard is offline
Mein Auto: 2007 X3 MT
Didn't read this thread last summer when you posted this, and it looks like you have moved on to a different connection.
But for the benefit of anyone else with this problem, here's an easy fix. I also have a Galaxy S4, but I also had the same problem with my old BlackBerry.
When the cable is plugged into the aux jack, and then plugged into the phone, sometimes the phone doesn't recognize the cable. The solution is to plug the cable first into the phone, then into the aux jack. Well that's really inconvenient, considering the stock location of the aux jack practically in the rear seat. So my solution was to buy a short extension cable. So essentially I have a 2 piece cable with a jack next to me by the console. Plug the end into the phone. If the phone doesn't recognize the connection, I just unplug the extension cable next to me from the main cable, and then reconnect it. The phone then recognizes the connection.
Not elegant, but it works.
Old 09-27-2014, 07:42 AM
Mein Auto: 06 X3
Just sharing my experience.
Iphone 5- after some time (30/50minutes) radio unit ,apparently, loses the connection to iPhone. This behaviour is corresponding to the temperature of the iphone. As soon as phone heats up while operating the connect ion is lost.
Samsung g2- wont even detect that it is connected to aux.
