Old 08-18-2013, 10:03 AM
drboomer drboomer is offline
Mein Auto: 2011 328i xDrive
e90 coding success
Successfully delete my orange sidemarkers!
(not sure why one side has the lights off, camera issue)
If you're looking to do the same I followed this guide step by step:
http://www.e90post.com/forums/showthread.php?t=588311
Old 09-15-2013, 01:52 PM
Alan328xi Alan328xi is offline
Mein Auto: 2011 bmw 328xi
You have halogens headlights, right?
Old 09-15-2013, 02:41 PM
hongsc hongsc is offline
Mein Auto: 2011 BMW 328i sedan
They are halogens.
2011 BMW 328i Space Grey|18" Avant Garde m359|Michelin Pilot Sport A/S|Eibach Pro-Kit Springs|Lux Angel Eyes|Philips HID Kit|Megan Racing Exhaust
Old 09-15-2013, 04:45 PM
If I will buy LUX AE, will I have to code anything?
Old 09-17-2013, 09:58 AM
I coded out my orange corners. Makes it look much more clean.
http://i.imgur.com/WzfqDCj.png
Old 09-17-2013, 07:07 PM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
The AE out on one side is a property of LEDs. Often times, PWM is used to dim bulbs as is the case with your stock halogen bulbs. The PWM frequency is too fast for the human eye to see but through a camera's slow frame rate, you see flickering. This does not happen with halogen bulbs since they have a "warm up" time and are not instant one, like LEDs are.
Old 09-17-2013, 11:25 PM
No they won't generate errors. But if you want to run them as DRL then you do need to code them.
Old 09-18-2013, 06:05 AM
Originally Posted by fdriller9 View Post
the ae out on one side is a property of leds. Often times, pwm is used to dim bulbs as is the case with your stock halogen bulbs. The pwm frequency is too fast for the human eye to see but through a camera's slow frame rate, you see flickering. This does not happen with halogen bulbs since they have a "warm up" time and are not instant one, like leds are.
pwm?
Old 09-18-2013, 07:20 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Originally Posted by drboomer View Post
pwm?
Pulse Width Modulation.
Often times, PWM is used to dim bulbs as is the case with your stock halogen bulbs. The PWM frequency is too fast for the human eye to see ...
Well, yeah, it's supposed to be. Sometimes the illusion of continuous illumination is due more to the physical response of the lamp (e.g., the heating & cooling time of a filament) than persistence of vision. Plug an LED into such a circuit and the pulse frequency can become suddenly, annoyingly obvious.
Early Cadillac LED tail-light systems have this problem and it drives me insane whenever I'm stuck behind one. They're OK at full intensity (braking) but the pulse frequency and duty cycle chosen to dim them is (just barely) perceptible to direct vision. Worse, every time I blink or flick my gaze, the stroboscopic effect rewards me with a dozen images of the LED arrays.
Thankfully, GM seems to have corrected this in later models.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
