Old 08-18-2013, 03:32 PM
coolbho3k coolbho3k is offline
Mein Auto: 2007 BMW 335xi
Did this fall from my car?
I was driving and suddenly I heard a noise. Turns out I was dragging this suspension part
WTF is this thing? I know my suspension had been rattling a bit when in rough roads but I assumed it was some issue with the anti-roll bar. Did I hit this thing and drag it for a few hundred feet or did it fall out from under my vehicle?
Old 08-18-2013, 03:58 PM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
Sorry, hope you called for the hook!
Old 08-18-2013, 04:03 PM
The car drives fine
Old 08-18-2013, 04:23 PM
White D White D is offline
Mein Auto: 2011 335d Sport
Looks like the sway bar end link. Look for one on the opposite side of the car and you will see a matching one.
Car will drive the same under normal driving. The sway bar, and end links help handling during aggressive cornering.
Should be a pretty simple fix, unless the end link damaged something else. Just bolt in a new one.
Old 08-18-2013, 04:27 PM
Would it cause a rattling noise?
Thanks, and it's good that I can continue driving the car without serious issues... Will order a new end link once I verify the issue.
Old 08-18-2013, 04:37 PM
Yes, you would get a rattling if one end of the link was loose, or not connected.
Old 08-18-2013, 04:48 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
Marking in second photo looks to be an aftermarket part. I wonder if you ran over this part in the road and then it hung up in your chassis. The noise might be the rsult. Either that or someone put an aftermarket part on this car and then the rest is what you all have been discussing. Says US patent XXXXXX, brand name CTR or CTD.
Old 08-18-2013, 04:56 PM
Yep, that's why I initially thought I just ran over it before I discovered the rattling.
Old 08-18-2013, 05:03 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yeppur, sure is....
OP, this is a good lesson for us: Re-torque your suspension & drivetrain mounts, all of 'em, from time to time!
Old 08-18-2013, 08:47 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Marking in second photo looks to be an aftermarket part. ... Says US patent XXXXXX, brand name CTR or CTD.
Could easily be original equipment--the E9X 3 Series had about 5% US/Canadian parts content. That figure may have varied year to year but was never zero.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 08-18-2013, 09:43 PM
Ultm8drvnmchn Ultm8drvnmchn is offline
Mein Auto: 98 740il
OH SNAP!!!!
Old 08-19-2013, 05:34 PM
When I was ordering a replacement wheel lock key for the fifth time, parts guy at the dealership confirmed that it looked like a sway bar link part from my MY that would have been used, so I'll trust him. Especially since the clunking got worse today so I'll stop driving it until I replace it.
Old 08-22-2013, 03:07 PM
It wasn't from my car after all. Turns out I didn't screw the brake caliper back on tightly enough and a bolt fell and it was just dangling. Replaced the bolt and it's fine now.
