BMW 90C Thermostat For N62, N63, N73 Engines - Page 5 - Bimmerfest - BMW Forums
Old 09-02-2013, 04:10 AM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
Installed...not yet seeing the results I was hoping for. The car hovers around 99-100C when just idling with the a/c on. need to do some more driving. Also, anyone know the proper bleed procedure? I know the system is self-bleeding, but I also know there is a procedure. As of now I have just added more pure water and bmw coolant to the system by adding until the expansion tank was at the "max" level.
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 09-02-2013, 07:15 AM
KingSilverback KingSilverback is offline
The Silverback
Mein Auto: 2006 750Li
Re: BMW 90C Thermostat For N62, N63, N73 Engines
Read my first post. I posted the TIS instructions on how to bleed the radiator correctly, if you have air bubbles temp will get higher than it's supposed to. If you keep seeing high temps then you probably already have a leak somewhere most likely rear cover plate
Old 09-02-2013, 08:55 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Yea, I'm getting the same results. 99 at idle and 96-98 at highway speeds. I'm hoping its just air in the system. I totally missed KingSilverBack's updated thread on how to refill the system; so I have to go back and try to bleed the system. I noticed that the return stream into the coolant expansion tank is weak where as before it was a strong return back. Last night, I got air hissing out of the expansion tank when I opened the cap.
One other thing, I couldn't drain from the radiator b/c the stupid head of the plastic drain plug broken off and I couldn't get it out. So I lost what ever coolant when I disconnected the hose and tstat. There are no leaks , no leaks that I can see.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 09-02-2013, 02:03 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
That's what my car runs at without this T-Sat in it .
FYI =
I installed 1 of these in someones car , followed TIS & bleed the system
& STILL NO CHANGE ...
Went with the owner to the dealer Saturday & had the Dealer Bleed the System
Old 09-02-2013, 02:24 PM
Thanks for the feedback PAPER. Next Sunday's task was to drain the coolant and refill per TIS, Idk if I'll end up doing it if it doesn't help.
At this point, for $120 I'm down 6 degrees.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-02-2013, 02:41 PM
The Silverback
FYI =
You're forgetting to mention some people already have leaks. How is it possible my temp went from 103C to a high of 93C in city driving?
Obviously it works, but your system has to be sealed.
Sent from my SPH-L710 using BimmerApp mobile app
Old 09-02-2013, 02:46 PM
PAPER's Avatar
CRISP & CLEAN
Not trying to kill your joy , But if it is a 90 degree T-Sat
then it is obviously not working if your still at 99 right ???
the owner of the car I installed it in is extremely Pissed & he thinks
that the T-Sat is just a stock T-Sat . I felt bad & still feel bad
cause I'm the person who told him about it . I personally don't
know if it is a custom made T-Sat or not , The only thing I know ,
is it is not performing the way it is suppose to according the the seller .
now before KingSilverback comes in here & say's he must have a
leak someplace , I can confirm he does not have any leaks , & he
just recently had his weep hole done along with the rear cover &
all hose's & anything to do with the coolant system including a new
water pump . I know this cause I went with him to All German Auto
dropped off his car , Then I drove back down with him to pick it up .
Old 09-02-2013, 02:49 PM
PAPER's Avatar
CRISP & CLEAN
SORRY but he has no leaks !!!
& also I can't speak for your car as I have not seen it for
myself , nor did I do the install . I can only speak On my
Bubby's car cause I personally drove it to check the TEMP
myself & saw no change when I bleed the system & again
after the dealer bleed the system .
Old 09-02-2013, 02:52 PM
There's no joy to kill, so no worries there.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-02-2013, 03:31 PM
PAPER's Avatar
CRISP & CLEAN
from my post above ...
Old 09-02-2013, 03:45 PM
The Silverback
So let me get this straight, YOU the guy who was against my review of this thermostat recommended it to a good friend? Why would you recommend something you don't believe in to a good friend? And then you also pressure tested his system and you're sure there are no leaks? Cmon Bro First_745Li is down 6 degrees so quite obviously something changed.
Old 09-02-2013, 03:48 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
Has the Tstat been tested on the stove to see that it opens at 90C?
Old 09-02-2013, 03:49 PM
The Silverback
Video of my temps with this thermostat.
Old 09-02-2013, 04:11 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
That's a great idea!
Based on the manufacture reviews, I can imagine there will be some variance in the quality and consistency of the thermostat.
kmatthews kmatthews is offline
Mein Auto: 750li
No video...
Old 09-02-2013, 04:13 PM
The Silverback
Originally Posted by kmatthews View Post
No video...
I'll re check links when I get home, they work when I click em
Old 09-02-2013, 04:14 PM
PAPER's Avatar
CRISP & CLEAN
never said I was against your review , I just wanted to inform
people of the company's feedback ( which is horrible ). I also
never said I recommended it to my friend , I said I was the 1
who told him about it . He made his own choice to purchase it
to try it out . In-fact I told him not to waste his money .
( the T-Sat just happen to come up in conversation )
As for pressure testing his system , After I bleed the system
according to TIS & we saw no change . I went with him to
a local radiator shop & was there with him when they pressure
tested it , & all was ok with no leaks . It not having any leaks
did not surprise me 1 bit considering he had the weephole ,
rear cover , water pump , & all hose's changed last month at
All German Auto when his coolant pipe went out .
As for First_745Li 6 degrees , I can't speak on it . As I stated before
all I can speak on is what I have personally seen or worked on myself .
It did not change in my Buddy's car & his car was running at 99 at idle
and 96-98 at highway speeds before we swapped out his T-Sat . Which
is the same Temp First_745Li say's his is running at after the swap .
EDIT =
Now if it is a 90 degree T-Sat , shouldn't it be
running a lot cooler than 99 degree's ???
Old 09-02-2013, 04:15 PM
PAPER's Avatar
CRISP & CLEAN
SORRY no video here ???
Old 09-02-2013, 04:17 PM
PAPER's Avatar
CRISP & CLEAN
X2 that is a great idea ...
Old 09-02-2013, 05:56 PM
The Silverback
Water boils at 100C, Thermostat looks very open to me
Old 09-03-2013, 04:42 AM
Alright...here is MY (unbiased) review. First off, let me say this is just what I have done and what I have experienced. The thermostat is installed in my 2008 750. Upon receipt of the thermostat I noticed that is looks pretty much the same as stock. I did notice that the connector on mine was 90 degrees counter-clockwise from where my stock one is. I opted to NOT modify my stock thermostat and just installed this new one. My initial indications were temperatures around 99-100C. Now after doing the proper bleed procedure the temperatures have come down a bit. If I do not use the air conditioner then I can typically get temps around 93-94C. Now with the A/C on it takes it up to around 96-98C. My biggest issue with the thermostat right now is that it is giving me a Check Engine Light. I read the errors with INPA and sure enough it shows thermostat. I reset it and it came back on the next drive. I have no leaks in my cooling system. I may have to do the hybrid mod in order to get rid of the CEL. Maybe mine is just a defective one and the seller will send me a replacement? I obviously still have some more testing to do but there IS some difference from stock.
Old 09-03-2013, 04:57 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
I've had two thermostat faults that were low temp with my self modded unit.Thats in 20k miles.Im basically running same temps as above.Interesting why the faults occur irregularly,maybe time to minimum temperature effects the fault?
Old 09-03-2013, 06:17 AM
Would you consider swapping the element using the original housing, like KingSilverBack and I did? I had no choice. The connector on the new one was shaky then broke off during installation. I did notice it was counter clockwise also. I don't know if this means squat... but on the way to work I stopped for gas, shut the car down and still had the temp readings visible...well when I got back into the car looked at the temp at it was at 104 degrees.. I was like WHAT THE FAWKKK!!...I started it up and the temp came down to 98/99 and on my way to work it hovered around 96/97/98... got to work, shut the car off and it climbed to 101.. Can someone tell me if this is normal? I never looked at the temp before after I should the car off.. Can someone try this and see if it happens with their car?
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-03-2013, 06:45 AM
The Silverback
So you're roughly within correct temperature ranges which means it works. I suggested OEM housing to save you from such problems, switch out the elements and you'll be fine, don't know why you didn't do it when you installed it, also with ac on your temp is actually supposed to drop coz fan is on. Turn both your heaters on high, fans on low and drive around for 15-20min I'm guessing you still have a few air bubbles, that should get rid of em. You're almost there!
Old 09-03-2013, 08:59 AM
dolfan13's Avatar
Mein Auto: 545i
Temps will rise after shutoff because the coolant is no longer circulating.
760 760li e66 v12, 760li cooling system, coolant, hot
