Old 09-05-2013, 10:13 PM
Eric01525i Eric01525i is offline
Mein Auto: 745LI
engine seems like it maintained hp when fully heated up. You know, like when you first take off in the morning, full of pep!!
Old 09-06-2013, 11:43 AM
ssdriver27 ssdriver27 is offline
Mein Auto: 2003 745LI Alpine White
Originally Posted by Eric01525i View Post
I know i am junping in late, but i did buy the stst. and nothing but good luck for me. Constsnt 93-96c a/c on or off 75-80f outdoor temp.
B4 swap i was getting 101-104c
going from a 105 to a 90 degree thermostat is a difference of 15 degrees (correct me if Im wrong) you should be seeing 85 to 90 no more then 90 as this is the temp the tstat is rated to open. but if you are consistant whether on highway or in city and you are getting those temps and you notice a difference in pep thats great.... Sorry if I seem negative Im just still mad about the price and quality of this part adn the fact mine is not working correctly. Im seeing 96 - 98 on highway (should be 85 - 90) in 60F outside temps. $120.00 plus 30.00 for coolant for 5 degrees cooler temps ...............
Old 09-06-2013, 12:40 PM
KingSilverback KingSilverback is offline
The Silverback
Mein Auto: 2006 750Li
Re: BMW 90C Thermostat For N62, N63, N73 Engines
You my friend have a problem somewhere in your cooling system if you're seeing temps that high on highway. Like I said at the beginning of all this, the thermostat won't do anything for you if you already have a leak or something already wrong with your cooling system. Get your car checked out or simply get a refund.
Sent from my SPH-L710 using BimmerApp mobile app
Old 09-06-2013, 01:59 PM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
ssdriver,
I agree with you.. the quality is ehhhh!.That's why KingSilverBack recommended the element swap from the beginning...Is it worth $120 to have a difference of 5-6 degrees? No.
What you should understand is that if your cooling system has no issues, sealed with no leaks then you'd see results like KingSilverBack and a couple of others have reported. However, if you have issues within your cooling system you won't get the desired results we all hope for. I'll tell you my story...
As you are aware, I installed the lower temp tstat, my temps are at 100C at idle... I too was pissed. Shouldn't be... right? Ok well I decided to get a second opinion from another INDY, and mentioned something I've noticed a while now - after driving 40 mins in traffic I can still grab the lower radiator hose and not get burned, this shouldn't be the case..
Had my car checked out this morning, here's what they found:
1. Pressure tested - no leaks
2. Good flow with some hot spots
3. Thermostat functions - fine
4. Upper Hose temp - 204F
5. Lower Hose temp - 135F
Diagnosis:
Collapsing or Failing Radiator
Based on the evaluation, I believe when I replace the radiator I should see major improvements on the temp... as long as there's nothing else wrong with the cooling system. I plan to get this repaired some time next week and will post up the outcome. I strongly recommend getting your car check out like I did.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 09-06-2013, 02:09 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
Originally Posted by First_745Li View Post
ssdriver,
Diagnosis:
Really, they say you have a bad radiator?
Bring back Sfbay, I want to know what he thinks.
Old 09-06-2013, 02:44 PM
lol....i know right.. You think different?
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-06-2013, 03:10 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
your radiator could be bad . It could be clogged or to much build up in it .
Old 09-06-2013, 03:16 PM
GeoX750Li's Avatar
I don't remember reading your engine temps were that high, just not in line with the 90C tstat. Did you have any collapsed hoses, that could be sign of a blocked radiator?
Old 09-06-2013, 04:07 PM
Just saw it at 100 this morning.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-06-2013, 04:34 PM
Thanks again First. gives me hope. I will check mine out more this weekend. Believe me when I say I want to give praise on this part. just need to get mine to work. I will look into it more this weekend. Im leaning towards it being clogged though rather then colapsing, could be the reason you mentioned low return stream after install of the new stat ........
Old 09-06-2013, 04:54 PM
Both hoses look good.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-06-2013, 06:12 PM
GeoX750Li's Avatar
100C is not really high for our cars. If your car can maintain that coolant temp for a long drive on a hot day, it seems your radiator is working.
Our engine temperatures depend on a lot of things. I drove home in stop and go highway traffic tonight. My coolant temp was 87C to 90C the entire drive. This is with the stock thermostat. Oil temp was 105C.
Old 09-08-2013, 06:37 PM
Before I jump into these repairs, I PMd BMWOEM1 to see how he would handle it. Waiting on his reply.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 09-09-2013, 03:16 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Just because a tstat opens at a certain temp that dosnt mean you'll run at that temp.Your car will run at a certain temp with no tsat right?Good test would be to remove element altogether in 85f weather ,stop and go and see what the engine maintains.Some cars depending on problems will still over heat.By the way going from 105C -108C to 95C-98C is a LARGE drop.Almost 20F.
Old 09-09-2013, 07:19 AM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
I think some people largely underestimate the even 10C (18F from 105c/221f to 95c/203f)difference. The fact the pressure will be lower so less stress on cooling components so extended service life on that side plus lower engine temps which will appease a plethora of issues with the cheap rubber and thermoplastics in the engine bay.
All that being said i am certainly disappointed with the quality of the product and it is a shame that if he was being honest (why make it up) that even he paid 50 a peice for these if i had gotten them all flimsy with the connector the wrong way id have sent them back and demanded to either fix it and compensate me or refund my money who wants 100 incorrectly manufactured tstats? Its great that you can hybrid them and it will work fine however it is a little too late for most these cars unless maybe you have a facelift with less than 40-50k(even thats pushing it)on it the heat damage has probably already taken its toll on the seals and cooling system and your best bet would probably still involve an engine reseal and cooling system overhaul and THEN the tstat will show its full effectiveness on the longevity of the engine and it's seals and plastic parts, and of course the added "peppiness" is a plus too.
If the n63 & n63tu guys do this now it would be interesting to see how well the new cars with a modified lower temp stat compare with reliability to stock temp cars. But as far as i can tell this doesn't feign much interest in the newer model forums.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 09-09-2013, 08:14 AM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
Originally Posted by KingSilverback View Post
Hows the cars performance now? Have you tried pushing her a little?
Yeah...there is probably a small HP gain as expected. My check engine light is back though. Says basically the DME control loop for the thermostat is open. If I can pick up a couple stock thermostats for not too much I may try a couple other tests with simply drilling hole(s) in the tstat. Temps usually range between 92-94 once fully heated up. There is definitely a slight increase based on engine load (A/C on, climbing hills, etc.) If the CEL was gone I would be happy.
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 09-09-2013, 08:30 AM
dolfan13's Avatar
Mein Auto: 545i
Yep 745iguy I had just pulled the engine and replaced every seal in it.Including the valve seals.So we will see about longer life.Im at about 15k on modded tstat and did seals about 30k ago so....The stock tstat is so easy to mod by the way.
Old 09-29-2013, 08:03 PM
gammodm gammodm is offline
Mein Auto: 2004 745i
Any updates ?
Old 09-30-2013, 11:58 AM
Now that the outside temps are down under 100F it consistently operates and maintains temps around 89-92C for me.
Gas milage is a tad bit worse, but performance is a tad bit better also.
Old 09-30-2013, 01:45 PM
This is not completely correct. Reason being, when the thermostat closes it allows the radiator to do its job and cool down the water that is trapped in it. Then the thermostat opens and allows the cooler water to circulate into the engine, then it closes again and the now hot water in the radiator has a chance to sit there and cool down while the engine is heating up the newly cooled water then again the thermostat opens and the process starts over.
if you run no thermostat the engine will take a very long time to warm up to operating temps and will not be consistent because the coolant will not stay in the radiator long enough to cool down, so ambient temps will effect the engine temps more so than with a correctly operating thermostat.
That is also why drilling a small hole in the thermostat works to a point. cause you're constantly circulating a bit of the coolant (enough that it is mimicking a cooler running thermostat but not too much that it is like removing the thermostat altogether)
Old 09-30-2013, 01:48 PM
and yes if the thermostat is working correctly it WILL run at or bellow the rated thermostat with only one exception that I know of and that is that you are running a HIGH horsepower motor and the heat produced is too much for the cooling system to efficiently cool the motor.
Old 09-30-2013, 04:18 PM
dolfan13's Avatar
Mein Auto: 545i
First part of this is not true .Hotrod mag. did extensive test and I have seen many arguments over this.The fluid does not need to stop in the rad to be cooled.A thermostat does one thing only: Its job is to block the flow of coolant to the radiator until the engine has warmed up to a temperature determined by the manufacturer. By letting the engine warm up as quickly as possible, the thermostat reduces engine wear, deposits and emissions. That's it. Once it's open it's the same as not having one.Also under the slowdown theory the coolant stays in the hot engine longer.
Old 10-01-2013, 11:59 AM
You are leaving out an important fact. Without a thermostat in place you will have an inconsistant operating temperature, and that temperature will depend on a number of things such as work load on the engine, ambient temps, vehicle speed, even oil change intervals because of less viscosity and amount of metal content in your oil, so as far as the operating temp not being effected by the thermostat I will agree to disagree.
Simply put regulating the flow will regulate the operating temps. and will be more consistant than not regulating the flow which is exactly what a thermostat does. The thermostat DOES open AND close during normal operation in order to reglate the operating temps, and will not be the same as running no thermostat at all.
Old 10-01-2013, 02:47 PM
Mein Auto: 745LI
I have now had this stat. in my car for aprox. 1 month. I am still running 93c with a/c on or off (always moving), in traffic nothing higher than 96c.
it does not seem to matter what the outside temp. is. We have had 60f days and 90f days, engine temp. is very solid.
FYI my car is a 745LI 2005 with 115,000mi never had cooling system worked on (other than y pipe). previous owner used car for highway only, I have all maint records and I am second owner, purchased with 98,000mi on car.
Old 10-01-2013, 04:10 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
ssdriver,
Diagnosis:
I didn't read this hole thread so maybe I missed something, but this caught my eye - I'm assuming we have basically the same cooling system - The lower hose will be cooler then the upper.
The radiator is made from aluminum and is divided into a high-temperature section (upper) and a low-temperature section (lower) by a partition wall. The coolant first flows into the high-temperature section and then back to the engine, cooled.
Some of the coolant flows through an opening in the radiator partition wall to the low-temperature section where it is cooled further. The coolant then flows from the low-temperature section (when the ÷WT thermostat is open) into the oil/coolant heat exchanger.
Also, the water pump impeller is made from reinforced plastic - it could be worn with age and not pushing max coolant (flow).
760 760li e66 v12, 760li cooling system, coolant, hot
