E34 (1989 - 1995)
Old 08-21-2013, 10:40 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
E34 Cranks Like Spark Plugs Are Removed:
This E34 sat for three years due to an electrical problem. When I got the problems worked out, it started instantly and idled like brand new. I ran it for a while and restarted it to move it around in the shop several times.
I replaced the spark plugs and compression was 160 across the board. The oil was super clean, but I changed it anyways. The car has less than 100,000 miles on it.
The car then sat for about a month until this morning. I went out to start it and it cranked just like the plugs were out. You could see the crank pulley turning but no compression impulse whatsoever could be heard.
After letting it sit about 15 minutes, it started, but ran roughly. No smoke whatsoever, just rough running, as if it were only running on 3 cylinders.,
After about 2 minutes, it smoothed out and idled perfectly. I drove the car and power is good all the way to redline/shift point with no smoke.
Are these a hydraulic lifter motor????
That's my suspicion at least now anyways.
Thanks for your expertise...
"Herr Doktor will see you now..."
Old 08-22-2013, 09:19 AM
Mein Auto: BMW 525i
Ran the car for several hours yesterday and drove it. This morning, same thing....cranks like plugs are out, then starts hitting on 1-2 cylinders, then starts, runs rough and eventually picks up all 6 cylinders.
GRRRRRR!!!!!!!
Old 08-22-2013, 10:09 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
what motor? M20? M30? M50NV? M50 VANOS?
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 08-22-2013, 12:47 PM
Mein Auto: BMW 525i
M50TUB25 I think...
Old 08-22-2013, 01:51 PM
Monsignor's Avatar
Mein Auto: Sig
And you have compression and new plugs? Sounds very curious.
I'vve never heard of this problem before, so heres a shot from the hip:
they have gigantic!!! power demands. so maybe theres just enough juice to get it slightly fired until the alternator can charge it up? Do you have an aftermarket radio or anything that would drain power when its not in use?
Maybe a video of the hard start and smooothing of the idle?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-22-2013, 01:54 PM
Mein Auto: BMW 525i
All stock...new MBZ battery. Cranks without ANY compression impulse cold...exactly like the plugs are out. Cranking speed is unreal....
Old 08-22-2013, 02:34 PM
Monsignor's Avatar
Mein Auto: Sig
you said it sat for a very long time after the compression test. Maybe you should have it checked again. Compression and Leak Down tests are very very very telling
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-22-2013, 02:41 PM
squidky squidky is offline
part time deutchelander
Send a message via ICQ to squidky
Mein Auto: e34 1993 525i
Re: E34 Cranks Like Spark Plugs Are Removed:
I would pull the coils again and checkto see if you are getting water intrusion in the coil valleys. I just had the same thing happen. A replacement valve cover gasket and some locktite grease on the coil bolts and holes did the trick for me.
Sent from my SAMSUNG-SGH-I537 using BimmerApp mobile app
Old 08-22-2013, 02:43 PM
Mein Auto: BMW 525i
Compression after sitting 3 years was 150 psi.
Now after driving it compression is 165....Leak down hot is only 10-12% and the motor has less than 100,000 miles on it...
Old 08-22-2013, 02:55 PM
Mein Auto: BMW 525i
When you crank it cold, the engine just spins without ANY compression impulse...it has no discernible compression when cold and I am convinced it is valve related.
Old 08-22-2013, 03:05 PM
Monsignor's Avatar
Mein Auto: Sig
The M50 does have hydraulic lifters
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-22-2013, 03:24 PM
Mein Auto: BMW 525i
I'm leaning toward that or a VANOS problem. It's definitely a compression loss from the valvetrain that disappears when hot and compression and power are both good when its warmed up...
Old 08-22-2013, 04:04 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Could it be the oil........
Old 08-22-2013, 04:06 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Hello Doc. Thia may not be worth 2 cents, but it may be worth trying. When the DME on my E36 (M50 with vanos) went out, and I tried cranking the car, it SOUNDED exactly like there was no compression. In fact, I was getting no fuel or spark due to the bad DME.
My supposition (and it's a fairly weak one at that) here is that you are lacking fuel from either a clogged fuel filter or a bad fuel pump.
You can get a can of starting fluid. If the car again will not crank and sounds like you have no compression, give a 2-3 second burst of the starting fluid into the airbox while someone is cranking the engine over. If the car fires immediately, then it most likely confirms my therory. It would just cost the price of a can of the starting fluid.
If it does fire up this way, then you can trouble shoot your fuel delivery system for the actual culprit. Wouldn't hurt to check fuel pressure at the rail as well.
Again, this is kind of out there, but very inexpensive to check out.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-22-2013, 04:32 PM
Mein Auto: BMW 525i
Hmmmm.....interesting.
I installed a Red Label '413' DME in this car because the Silver Label was bad. It fired immediately (its an EWSI car) and has run flawlessly ever since. The car has been started hundreds of times over the past few months and always starts before you can let off the key.
When you go out in the morning, the car will crank like the plugs are out, accompanied by a clanking noise I have never heard before. Then, the car will start to 'hit' on perhaps 2 cylinders and then start and shake violently until it smooths out.
After that first start it runs perfect all day long!
Old 08-22-2013, 04:33 PM
Mein Auto: BMW 525i
I'm not sure.
I think we put 5/30 or 10/30 Mobil 1 in it because that's what we had in stock....
Old 08-22-2013, 08:40 PM
Robinson Crusoe Robinson Crusoe is offline
Mein Auto: 1994 530i 195k miles
Originally Posted by Doktor Bert View Post
I'm not sure.
Next time try to look up fluid specs. Respect your work.
Old 08-23-2013, 07:01 AM
Monsignor's Avatar
Mein Auto: Sig
I'm leaning toward...a VANOS problem.
Not this. VANOS would not have a ny effect on the valvetrain during startup. I would absolutely look into EWS as Steve said
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-23-2013, 09:20 AM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Im thinking valves or lifters..
Can or does the valve train posses the ability to reduce compression upon start up to make cranking easier?
Can the lifter lose there oil and not open close valves till sufficient oil pressure is achieved? This being the tick?
Sounds like either oil pressure or something else needs to occur first to start.. Find out what its missing
Old 08-23-2013, 09:50 AM
Mein Auto: BMW 525i
EWSI has been bypassed.
During cranking, the 'tapping' is actually compression coming up into the intake manifold. However, there is a 'rattle' that appears only when cold. The engine is dead-quiet when warmed up. I am starting to think the chain may be jumping when cold and then jumping back when warmed up, possibly a bad tensioner.
Fuel pressures and volumes are within spec. Adding supplemental fuel does nothing since there is zero compression available to ignite the fuel.
Swapped in another 413 DME and it does the same thing.
Today I will examine piston crowns with a bore scope to determine if we have valve/piston contact....
Old 08-23-2013, 09:51 AM
Mein Auto: BMW 525i
I don't know of anything in a M50TUB25 that wouldn't like Mobil 1. Anyone else care to chime in??? The problem appeared immediately after an oil change...
Inside of motor is spotless, with none of the 'reddish/brown' slime you commonly see in these engines. 94,000 mile original owner car...
Old 08-23-2013, 10:04 AM
Monsignor's Avatar
Mein Auto: Sig
I really am stumped with this one. I would tear the top end down.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-23-2013, 10:08 AM
Resident e34 Racer
I know a car can jump timing, i heard that.. But jumping back??? Does this actually ever happen?
Never heard of it jumping back
Old 08-23-2013, 10:16 AM
Mein Auto: BMW 525i
Maybe it never jumps back. Perhaps once it's running the hydraulic tappets adjust to the new, yet incorrect timing setting.
It's definitely in the valvetrain...
Old 08-23-2013, 10:24 AM
Resident e34 Racer
These car must need to be driven.. If i let my car sit for days i get a light tick till it starts to warm up ect.. She gets all creaky for a few miles..
As a DD theres no issue
