E34 (1989 - 1995)
Old 08-23-2013, 09:32 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
This appeared after the oil change, but I believe that's only coincidence....
"Herr Doktor will see you now..."
Old 08-23-2013, 10:42 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
I have to agree. Do you think you could get a video up?
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 08-23-2013, 11:23 AM
Mein Auto: BMW 525i
I'll try....funny that a chain/tensioner would be out on a 94,000 mile car. I have seen many M50's with 100-000 to 150,000 on the original chain...
Old 08-23-2013, 01:07 PM
Monsignor's Avatar
Mein Auto: Sig
243k here on original chain.
Chain could just be worn from not being used.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-23-2013, 01:24 PM
Mein Auto: BMW 525i
Tomorrow we will know...
Old 08-23-2013, 01:33 PM
Mein Auto: BMW 525i
I hate you.....
Old 08-23-2013, 01:59 PM
Monsignor's Avatar
Mein Auto: Sig
I hate you.....
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-23-2013, 02:01 PM
Mein Auto: BMW 525i
Lol!
Old 08-26-2013, 09:20 AM
Mein Auto: BMW 525i
After doing considerable research on this topic, I have discovered this is a fairly common problem. I found numerous threads where people simply walked out and got into their car after parking it several hours before and it cranked as if the plugs were removed - compression tests revealed 0 pis. Of all the threads I read, nobody has yet repaired the problem and in almost every case, they just replaced the engine or junked the car.
I spoke to a fellow in Newport Beach Saturday that has a 95 525i with 67,000 actual miles and he and his wife went to dinner, walked out 45 minutes later and the car cranked like the plugs were out. The local BMW firm recommended a replacement engine, so we will never know the exact cause, but I suspect a relaxed chain tensioner and/or bad VANOS.
I will pull the top off the M50TUB25 on Saturday....
Old 08-26-2013, 10:51 AM
Monsignor's Avatar
Mein Auto: Sig
in for motor teardown. I cannot see how a faulty vanos would cause this.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-26-2013, 11:11 AM
Mein Auto: BMW 525i
I actually suspect the VANOS more than anything.
During cranking, you can hear the engine spitting through the intake, as if the compression impulses are being vented out the intake valves, and since the VANOS controls the intake camshaft, if it was stuck in the advance position, this is a definite possibility.
Found many threads about this...
Old 08-26-2013, 11:29 AM
Monsignor's Avatar
Mein Auto: Sig
I have a VANOS unit if you'd like.
So your theory is its trying to crank/fire out of time.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-26-2013, 11:31 AM
Mein Auto: BMW 525i
At the moment, I suspect the VANOS, but I haven't had time to open it up just yet. Could you post a cutaway of a VANOS???
I need to educate myself on this system....
Old 08-26-2013, 11:46 AM
Monsignor's Avatar
Mein Auto: Sig
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-26-2013, 11:57 AM
Monsignor's Avatar
Mein Auto: Sig
Given that information, i can see where youre coming from in that the motor is trying to fire and turn over while it is not timed.
Yes VANOS will advance timing, but thats under circumstances. A worn tensioner would show the same effects just by being old.
Also please check out Part #16 in the above diagram. The crank is attached to the exhaust cam on the main timing chain, and the exhaust cam to the intake via another, separate, chain, with its own tensioner.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-26-2013, 12:05 PM
Mein Auto: BMW 525i
Thanks!!!!
I will keep you posted and I greatly appreciate your input!!!!!
Old 08-27-2013, 10:02 AM
Mein Auto: BMW 525i
VANOS - Very Awkward Non-functioning Ominous System
Old 08-27-2013, 10:45 AM
Monsignor's Avatar
Mein Auto: Sig
LOL!!!
sounds like you feel as though you may have found the problem
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-27-2013, 11:06 AM
Mein Auto: BMW 525i
LOL!!!
Not yet, but I think it could be a combination of a failed tensioner and a stuck VANOS.
Old 08-27-2013, 12:03 PM
Mein Auto: BMW 525i
Finding many symptoms of this in other BMW's:
Instant compression loss BMW M3:
http://www.m3forum.net/m3forum/showthread.php?t=246935
Sudden loss of compression:
http://www.bimmerwerkz.com/forum/3-s...ion-16512.html
BMW 325 sudden compression loss:
http://www.digest.net/bmw/archive/v10/msg01054.html
BMW 318 sudden compression loss:
http://forums.bimmerforums.com/forum...of-Compression
BMW 530i sudden compression loss overnight:
http://forum.roadfly.com/threads/187...ion-on-530i-v8
Old 08-27-2013, 12:24 PM
Monsignor's Avatar
Mein Auto: Sig
thats alot of reading LOL. dont have time at work. will read through them when i get home.
I can't wait to see how vanos would cause instant total compression loss. Anytime i've heard or seen Vanos problems is the Vanos rattle.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-27-2013, 12:27 PM
Mein Auto: BMW 525i
me too. I am no BMW expert, so this will be a learning experience for me as well and I hope to get the E34 running so I can complete the restoration and, hopefully, my findings may shed some light on this apparently common problem.pe
Old 08-27-2013, 12:51 PM
Monsignor's Avatar
Mein Auto: Sig
unplug the vanos solenoid and try to crank it.
This will disable the unit and potentially allow the motor to "retime." It WILL throw an engine light and if car does fire, it would only mean faulty vanos, not fixed car. It should be easy to follow under the intake manifold. Removing the airbox makes it much easier.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-27-2013, 01:04 PM
Mein Auto: BMW 525i
Hmmmm....good idea, but isn't VANOS disabled until elevated RPM????
It is interesting that once you do get it started (after lots of cranking like it has no plugs) it does run and idles velvet-smooth with good power, so if valves were indeed bent, I don't think I would have a smooth idle when warmed up.
Old 08-27-2013, 01:32 PM
Monsignor's Avatar
Mein Auto: Sig
the solenoid may not be reacting to oil pressure via revs. It may just be stuck open? as in cranking with the timing advanced? once the car is in accessories and the oil pump is primed, the timing is advanced. Thats my theory.
Give it a shot. theres no harm in it, and you would get a quick and dirty answer, or at least a bit more information.
Your valves are not bent after sitting.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
