E34 (1989 - 1995)
Old 08-30-2013, 08:30 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Originally Posted by Doktor Bert View Post
My big question is why the VANOS is receiving a signal at idle. This should not get a signal until elevated rpm's, correct??? If I plug it in, with the engine at idle and fully warmed up, the engine begins to 'lope' as if it is about to stall, so I unplug the VANOS again.
However, leaving the car sit overnight with VANOS unplugged changed nothing. I still have zero compression when cold start is attempted...
It would recieve instructions to be closed.
Thats the signal the solenoid is getting:
0 - idle and regular driving normal operating oil pressures
1 - WOT/high rev - subsequently elevated oil pressure
lopey idle means its advancing timing. Im sticking to my guns here on a busted solenoid.
When its unplugged idle seems fine? Chain tensioner pulls the cam back in time and vanos is retarded.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 08-30-2013, 08:33 AM
Monsignor's Avatar
Mein Auto: Sig
All things suspect must be examined. Camshaft advance, at the inappropriate time, could cause compression loss. I am curious to know three things about VANOS:
1. What is the total amount of advance in degrees possible with this system?
I dont know. Enough to stall an idling car it seems
2. At what rpm does the system 'normally' activate?
also dont know this exactly
3. What sensor/values does the DME read before issuing a VANOS activation command?
I assume revs and throttle position
I have already verified there is no 'dribble' from the injectors and the port floors and cylinders are not wet with fuel. I will check and report other test conditions at lunch today...
I would say that a VANOS would advance timing enough to open valve to point of total compression loss. i believe 7k rpms or close to it is valve float.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 08:37 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
I appreciate your input, Monsignor. This is my first BMW and first real VANOS experience...
"Herr Doktor will see you now..."
Old 08-30-2013, 08:44 AM
Monsignor's Avatar
Mein Auto: Sig
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 08:45 AM
Monsignor's Avatar
Mein Auto: Sig
hopefully you can help with with a w115 if i ever find one haha
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 08:53 AM
Mein Auto: BMW 525i
Oh yes...Indeed!!!!
This is one of mine with over 1 million (documented) miles...
ID:	394287   Click image for larger version
Name:	300SD Full Tint.jpg
Old 08-30-2013, 08:54 AM
Monsignor's Avatar
Mein Auto: Sig
thats a gorgeous color
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 08:55 AM
Mein Auto: BMW 525i
Ok,
after lots of research, I have come across only ONE problem like mine where the engine was NOT replaced. The owner pulled the cover to find one cam grossly advanced, to such a degree that the cam holding fixtures would not slide into place.
He replaced both tensioners and that seems to have fixed it.
FYI...
Old 08-30-2013, 08:59 AM
Monsignor's Avatar
Mein Auto: Sig
Also please check out Part #16 in the above diagram. The crank is attached to the exhaust cam on the main timing chain, and the exhaust cam to the intake via another, separate, chain, with its own tensioner.
lol from monday
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 09:20 AM
Mein Auto: BMW 525i
LOL Indeed!!!!!!!!!
I am now fixing this only to say it didn't beat me.
Monsignor's Avatar
Mein Auto: Sig
holy sh!t. ^thats it. it is the tensioners. timing is advanced and the tensioners cannot pull the chain back to normal operation time. Its only after its running that it slowly twists back on its axis.
Replace both.
Tensioner between Cams $43
Main timing chain tension $19
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 09:26 AM
Mein Auto: BMW 525i
I think you could be correct!!!
ironic the tensioners failed with less than 100,000 on the clock, don't you think????
Old 08-30-2013, 09:28 AM
Monsignor's Avatar
Mein Auto: Sig
I really think its an age thing. Theyre just old!
Too bad seals and hoses aren't like a fine wine
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 11:02 AM
Mein Auto: BMW 525i
Don't they just employ O rings????????
Old 08-30-2013, 11:15 AM
Mein Auto: BMW 525i
Yep...
07-11-9-963-418-M131
50 cents...
Think I will try re-sealing them first and see what happens...
Old 08-30-2013, 01:01 PM
Monsignor's Avatar
Mein Auto: Sig
Yep...
50 cents...
resealing what? the tensioner?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 01:05 PM
Mein Auto: BMW 525i
Yes...sealing rings in both easily replaced. If that corrects the problem, and no valves are bent, then I will proceed with new units.
I don't want to invest too much on this $500.00 E34, since it still needs a Heater Pump, General Module ending in '571' Front Door Panels and Lower Rear Seat Halve.
Still have no power windows, door locks, power sunroof and low and mid-speed wipers with all fuses/connections verified as good, so that has me more concerned than the timing chain issue.
Old 08-30-2013, 01:06 PM
Mein Auto: BMW 525i
That's a sharp E34 in your profile....same color as this one!!!!
Old 08-30-2013, 01:09 PM
Monsignor's Avatar
Mein Auto: Sig
Awesome. I really think this will be it. deductive reasoning has me feeling confident.
I thank you! my father is the original owner, gave it to me when i was 12, very light resto, hapy miles ever since.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 01:12 PM
Mein Auto: BMW 525i
My wife is very eager to take delivery of this car. It was just repainted complete B/C-C/C (by a colleague), but needs to be buffed out. Everything stopped when the timing chain problem appeared...
Old 08-30-2013, 01:27 PM
Monsignor's Avatar
Mein Auto: Sig
hopefully we'll have discovered the answer then
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 02:13 PM
Mein Auto: BMW 525i
UPDATE:
Oil added to cylinders has no effect - cranking compression is still zero. With throttle blocked (WOT) compression impulse can be heard exiting into the intake manifold.
Yep, this M50 is outta time...
Old 08-30-2013, 02:30 PM
Monsignor's Avatar
Mein Auto: Sig
tighten up the chains it is....
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 08-30-2013, 02:38 PM
Mein Auto: BMW 525i
This thread seems to have the most relevance...
http://www.bimmerfest.com/forums/sho...d.php?t=716701
Old 08-30-2013, 02:39 PM
Mein Auto: BMW 525i
And let us hope we don't have any bent valves...
