Old 08-22-2013, 06:00 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Oil Temperature.
Today, me and a friend with an M3 decided to go out on a nice drive up the mountains to try out the twists. However, I have never had my oil temperature go up close to 250 degrees Fahrenheit before. Can one expect the oil temperature to climb up a little higher when tracking the car or doing some spirited runs up a mountain?
Once a 6'er, always a 6'er.
Old 08-22-2013, 07:07 PM
HerbP HerbP is offline
I would start checking out your cooling fan. Since we do not have a coolant temp gauge, the oil temp will spike when the engine runs hot. When the cooling fan starts to fail, it will work for a while when cold. After that, it stops working at all. When the oil temp starts to climb, stop & check to see if the cooling fan is working.
Good Luck!
Old 08-22-2013, 07:09 PM
07 E63650i's Avatar
Freude am Fahren
Oil Temperature.
Good Luck!
I noticed that the temperature dropped as soon as we went downhill. So, it is not normal for the temperature to be near 250 degrees Fahrenheit, right? Also, do you know where the cooling fan is located? Thanks HerbP.
Old 08-22-2013, 07:16 PM
The oil temp will drop driving down the highway. When you stop with no air movement, the engine temp starts to rise. The coolant fan is located directly in front of the engine, in front of the belts. I would say any temps above to 230F, I would start getting concerned.
Old 08-22-2013, 07:39 PM
07 E63650i's Avatar
Freude am Fahren
Oil Temperature.
Thanks HerbP. Will have to take a look at that.
Old 08-22-2013, 09:30 PM
drzoom drzoom is offline
Mein Auto: 2001 330i, 2009 650i
Mine typically runs between 220 and 230 with the AC on a mixed city/hwy commute. I wouldn't be surprised if it gets higher with spirited driving uphill. Should I be concerned too?
2009 650i Sport
Old 08-22-2013, 10:38 PM
Yorgi's Avatar
Yorgi Yorgi is offline
My oil temp stays rock solid @ 230F under normal driving conditions but at the track or during hard driving in the mountains I have seen oil temps rise to over 300F.
The owners manual says the following about oil temps:
During normal operation, the engine oil temperature is between approx 160F and approx 340F. If the engine oil temperature is too high, a message is displayed on the Control Display.
So you should be fine as long as you don't go past the far end of the oil temp scale. But I would personally slow down long before I peg that gauge.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-23-2013, 01:30 AM
07 E63650i's Avatar
Freude am Fahren
Oil Temperature.
Originally Posted by Yorgi View Post
My oil temp stays rock solid @ 230***176;F under normal driving conditions but at the track or during hard driving in the mountains I have seen oil temps rise to over 300***176;F.
During normal operation, the engine oil temperature is between approx 160***176;F and approx 340***176;F. If the engine oil temperature is too high, a message is displayed on the Control Display.
Thanks for your experience Yorgi! I was hoping that a slight raise in temperature was to be expected as it was 95 degrees Fahrenheit today.
Old 08-23-2013, 11:07 AM
numoo numoo is offline
Mein Auto: 645 CI Conv
Mine has been at the near mid mark, drove it 500+ miles at a stretch over 2 days never had issues. Most cars op at 220- 260F as a norm from what mechanics tell me. Now if you needle is way past mid way then I would be concerned.
Old 08-28-2013, 02:23 PM
07 E63650i's Avatar
Freude am Fahren
Oil Temperature.
I drove the 650i today and the oil temperature stayed around 210-220 degrees Fahrenheit. That day that I was driving spirited in the mountains, the oil temperature was 230-240 degrees Fahrenheit. Outside temperatures for that day in the mountains were in the mid-90s and today was about 95 degrees Fahrenheit.
