Old 08-24-2013, 01:20 PM
IonutZ IonutZ is offline
Mein Auto: 2013 M6
Alpina Mod + JB4 possible issue
Hi there,
I'm running a 2013 E92 N55 with the Alpina trans flash, a BMS Air Intake and a JB4 on Map 5 with about 40% e85/ 60% 93 octane... recently I've been experiencing some issues randomly:
Every once in a while when leaving from a complete stop in M2, trying to shift to M3 between 2000-3000 RPM it won't shift - it'll show M3 but the trans doesn't shift.
Had a couple of incidents when I was in M1 above 6000 RPM where it didn't shift until it fell under 4000 (display says you shifted but... it doesn't).
Also one incident yesterday, started the car, put it in reverse and engine started to hiccup fluctuating RPM between 500 and 1500, once I was done reversing, put it in drive and it drove fine apparently - however one of the non-shifting above 6000 RPM incidents happened within 10 minutes of this event.
Have you had any similar experiences? This isn't very comforting
Old 08-26-2013, 06:31 AM
KAP8's Avatar
KAP8 KAP8 is online now
Mein Auto: Alpinweiss F32
Try doing a Google search and see if anyone else is having this problem. Before I got the Alpina flash, I did a ton of research. Most folks that had the Alpina transmission flash also had JB4. I don't recall reading any issues like you mention. I have the Dinan Stage 2 and don't have any "shifting" issues with the Alpina.
2015 435i ///M Sport | Alpine White | Coral Red | 19" | Auto | Cold Weather | Driver Assistance | Dynamic Handling | Lighting | Premium | Technology | M-Sport Brakes | Rear Sunshade | HK | Leather Dashboard | MPPK | MPE | Dinan Suspension | BMWCCA #409820
PCD: 10/31/2014
Old 08-26-2013, 07:24 AM
Mein Auto: 2013 M6
Well... I believe I was shifting too fast into 3rd at too low of a speed. However, I just experienced some low throttle idling issues when putting it into reverse for the second time yesterday.
Started car up, put it in reverse, hiccuped twice idling, but then everything was fine after that...
Old 08-26-2013, 08:06 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
To much e85
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 08-29-2013, 04:47 PM
Mein Auto: 2013 M6
OK so the Alpina has nothing to do with it... it's a JB4 issue, and this is how it manifests upon a cold start: (I am not touching the accel. pedal)
If you have experienced this, please let me know what the solution is... I've cut down e85 to 20% and it still does this. Car works flawlessly after the first 20s.
