Old 08-26-2013, 11:05 AM
Baby_Steve Baby_Steve is offline
Mein Auto: 2010 328xi
2010 E90 Comfort Access Problems???
Hello,
I just purchased a 2010 BMW 328xi and am having issues with the CA system. When I first purchased the car I was able to get in the driver's seat and simply press the brake pedal and push the Start/Stop button and my bimmer would start up. Recently that has not worked and I have to put the FOB in the little housing area to get the car to start now.
Why did it start requiring me to pull the FOB out of my pocket to start the car? Is there a way to turn this feature on and off?
Obviously this isn't a pressing issue, but I would like to know why this isn't working. I'm taking it to a dealer next weekend and will ask the same thing but figured I'd try here first.
Thanks in advance.
Old 08-26-2013, 11:57 AM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Originally Posted by Baby_Steve View Post
Hello,
Thanks in advance.
Lots of possibilities to be found in the 'search' function.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 08-26-2013, 12:24 PM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Could be a couple of things. It COULD be the battery in the FOB is low. BMW made it so that keys WITH CA can have their battery replaced (just pull it out and replace with a battery, they're cheap as hell), but keys WITHOUT CA, you can't really replace the battery yourself.
That being said, it could be the FOB sensor in your car (which I believe sits right behind where you insert the key) is wonky. In which case it'll be about $6-700 bucks out of pocket (not counting warranty) to replace. I remember a topic like this a while back with a similar issue. Get it checked out. But you should have a warranty either way, so nothing to really worry about (other than a few hundred bucks out of your pocket if it ends up being the sensor).
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 08-26-2013, 12:36 PM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
Replace battery. Report back.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 07-01-2014, 07:51 PM
rogerdiaz rogerdiaz is offline
Mein Auto: 2011 BMW 335d
Are there comfort access fuses? My keyless entry and keyless start not working. Fob has new batteries.
Old 07-02-2014, 05:24 AM
Turborascal Turborascal is offline
Canyon Carver
Mein Auto: 2011 E92 335is
+1 on the battery replacement. Procedure is in the owner's manual.
My comfort access was recently wonky ... replaced the battery and all is back to normal.
2011 Black Sapphire Metallic 335is Coupe | DCT | Luxury Pkg | Convenience Package | Cold Weather Package | iDrive/Nav/Sirius | Michelin Pilot Super Sports on 19" 313s
2015 Jet Black Metallic Porsche Cayman GTS | PDK | PASM | PTV | Sport Chrono | Power Steering Plus | Burmester sound w/nav | Park Assist with backup camera | Convenience Pkg
Old 07-02-2014, 01:27 PM
Mein Auto: '06 AW 330xi
Doesn't the car warn you when the battery in the fob is low?
How is keyless entry working? Normal? Or reduced range?
Old 07-02-2014, 01:50 PM
neo_andersson's Avatar
neo_andersson neo_andersson is online now
Mein Auto: 2014 640xd
Aerial for keyfob is under the ashtray, you will need to remove the center console trim to reach it.
CA in e90 has 4 aerials, 1 under the front ashtray, 1 in center console under the center armrest, 1 in the trunk under the lining and 1 under the rear bumper. The door handles of the front doors have also internal aerials to pick up your key when you try to unlock the car. If you can lock/unlock car easily but you have problem starting the engine, it might not be the battery but one of the interior aerials failing. Go to the dealer for a dignose as any aerial problems will show up. Aerials are not very expnsive and quite easy to replace. In Europe is about 40 so i will not worry about the cost.
328xi, ca, comfort access, fob, problem, unlocking
