Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 08-27-2013, 08:58 AM
TeaRex714's Avatar
TeaRex714 TeaRex714 is offline
Mein Auto: 2015 740Li
Vent fan problem - FIXED
My 2008 E90 has been having a problem lately with the blower not working. It started about a month ago when, just every once in a while, the blower won't blow on any setting (including MAX, so I think it's not the First Stage Resistor pack.) It would start working after 15 or 20 minutes (which is a hot 15 or 20 minutes here in Houston.) Now it hasn't worked for the last two days.
Any thoughts from anyone? Blower motor? (seems odd that it would be intermittent like that) Battery going out? (I've heard it can cause some weird problems when it starts going out.)
2015 740Li Black Sapphire Metallic. Her name is Samantha
2008 M3 Sedan Alpine White / Fox Red - Sold at 219K miles
Old 08-29-2013, 09:02 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
fsr is the place to start.
It is a very common issue on 3 cars & 5 cars, Also easier the replacing blower. Check you battery voltage as well. you can google instructions for replacing FSU on three series car.
Old 08-30-2013, 05:40 AM
650 Ryder's Avatar
650 Ryder 650 Ryder is offline
Mein Auto: Dinan///M3 - Countryman S
I'm going with FSR on this.........Phil
2011.5 Dinan ///M3:
SSII DCT
Comp, Conv, Prem 2 Pkg
Heated Seats
Enhnd Prem Sound
BMW Edition Grills / Gills
BMW M Perf. Steering Wheel
BMW C/F Perf. Spoiler
BMW Pedals
Dinan Exhaust
Dinan Mid Racing Exhaust
Dinan Carbon Fiber Intake
Dinan Racing Middle Exhaust Software
Dinan DCT Tune
Dinan Pulley Kit
Dinan CH-R Wheels
Dinan Carbon Fiber Strut Tower Braces
IND M5 Scheme Mirror Caps
Arkym Front Lip
C/F Reflectors
Lux H8 V3
Brembo 365mm BBK
Swift Spec-R Springs
Old 09-07-2013, 03:01 PM
TeaRex714's Avatar
I found a blower WITH the regulator already on for $140, so just replaced both rather than guess which one was the problem. The failure was still intermittent, so time will tell. Easy to get to once you remove the glove box and lie on your back on the passenger side floor
I did find some burned contacts in the regulator connection, but I don't know if it came from a regulator or blower motor problem.
