Old 08-27-2013, 10:23 AM
bilalrobinson bilalrobinson is offline
Mein Auto: 645Ci 2 door coupe
Window problems
I have problems with my 645Ci 2 dr couple. The windows will go down on their own after I have engaged the up button. I will push the up button and the window will start up and then will immediately go down. Is this a fuse or electric issue. Anyone else with this issue.
Please advise
Bilal
Old 08-27-2013, 04:59 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Hopefully you just have a switch issue.
It is more likely a problem with the window regulator which is not an ovverly expensive part (about $250) but the labor to install a new one will not be cheap. I would take the car into a good indie BMW mechanic to get it checked out.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-27-2013, 05:38 PM
RooK77 RooK77 is offline
Mein Auto: 645i
Try pushing the up button with the door open and see if it still go down. My driver side window sometimes go down if I close the window with the door closed. This problem is not present with the door opened.
If you window go up with the door open maybe the anti trap sensor is dealing with the pressure of your 9 years old door seals.
I would lubricate all the seals and try again. Hope some of this helps.
Old 08-27-2013, 11:29 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
Yep, I think the window is jamming & the anti-trap mechanism is kicking in. As the previous poster suggested lubricate the seals with Gummi Pflege. If that doesn't work there may be a problem with your window regulator, it may be cracked causing the window to jam at certain points.
Old 08-28-2013, 01:52 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Window problems
Humm, I had similar behavior about a year ago. Try this procedure to re-initialize the window, it's worth a shot
http://www.bimmerfest.com/forums/sho...d.php?t=630504
