Old 08-27-2013, 03:21 PM
dlwjdwns1992 dlwjdwns1992 is offline
bmw4life
Mein Auto: E92 328i Coupe
Eccentric shaft motor? On E92.
My car had problem with Eccentric Shaft sensor. They had replaced it and the problem atarted on the next day. The car stalled while driving.
The car has been in dealer for 2 weeks now.
They called me today and they might replace the Eccentric Shaft. (Im guessing motor).
Is this.... big problem?? Anyone know??
Sent from my SCH-I605 using BimmerApp mobile app
Old 08-27-2013, 06:17 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
The Valvetronic motor connects into the eccentric shaft which is connected to the valvetrain under the cylinder head cover. It isn't a huge job with the right tools.
Old 08-27-2013, 08:56 PM
bmw4life
Re: Eccentric shaft motor? On E92.
Should it fix the problem?
It is funny because my dealer told me that they will have to call somewhere to see if they let me get the shaft replaced.
The problem was after replacing eccentric shaft sensor. The car stalls while driving.
Old 08-28-2013, 05:11 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Special tools, or do you mean a well equipped mech?
Old 08-28-2013, 05:12 AM
Replace the shaft - isn't that extreme?
What exactly are they saying is wrong with it?
Old 08-28-2013, 08:22 AM
bmw4life
The car has service engine soon light.
The car stalls sometimes.
The error code they get is related to the eccentric shaft..
Old 08-28-2013, 09:33 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
The seal around the eccentric shaft sensor can deteriorate causing engine oil to get into the connector above the sensor. Hesitation in acceleration can occur.
The engine cover must be removed to see it. This is common on the N52 motor.
Look at this.
Old 08-28-2013, 09:50 AM
bmw4life
Look at this.
I just got back from dealer. They had order the Eccentric Shaft. And will be replaced tomorrow.
The engine cover and all the other stuffs were taken off but they couldn't find ANY problem. So they decide to replace the Shaft first and see.
I hope it fixs everything///
Old 08-28-2013, 09:58 AM
boramkiv's Avatar
Propellers Up Front
Okay, I admit I did read your entire post, but I completely disregarded the second sentence. They already replaced the sensor (duh) now it's time to replace the actual motor. Okay. Gotcha.
Old 08-28-2013, 10:00 AM
bmw4life
haha. yep!
Cause after they replaced the sensor... it stalled.
So i hope the Motor will have MUCH difference with it!
Old 08-28-2013, 12:07 PM
Shoot an arrow up into the air....where it falls....I know not....where....
Gotta wonder - was the sensor oily?
Old 08-28-2013, 01:26 PM
bmw4life
No clue. I dont know what is going on over there. Im just asking the dealer what the problem is... lol
Old 08-28-2013, 02:50 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
I've seen this fault caused by engine oil getting pushed through the engine harness connector via the eccentric shaft sensor. In some cases, the oil makes it way all the way to the DME. At that point, the sensor, engine harness and DME all need to be replaced.
Old 08-28-2013, 03:23 PM
bmw4life
hmmm... cause they did not told me that the oil was in it.
They said they couldnt find a problem. so they will just try replacing it and see if it fix the problem... arhhhh
