Old 08-28-2013, 06:34 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Crankshaft front seal replacement on N52
Hi,
The [front] crankshaft seal seems to be leaking on my '06 530i with 130K miles. After wiping everything clean, after couple of weeks of driving, I see oil on the front portion of the lower pan and on the bottom of the pan.
I don't believe the full flow body (oil filter housing) gasket is leaking. I've looked very closely with a flashlight. Everything above crank pulley is very dry.
Valve cover gasket is new and I am absolutely positive it's not leaking.
I also don't believe the lower pan gasket is contributing to this oil leak based on what I see on/around the pan gasket.
That leaves me with front main seal. Has anyone replaced front main seal on N52? Amazon and others sell a tools kit for around $130 (with shipping) to replace the seal and the seal is around $30. TIS states that we need to use loctite/glue after inserting the new seal. I am contemplating with DIY or give the car to dealer. Your thoughts please....
Old 05-28-2015, 12:35 PM
stilldre54 stilldre54 is offline
Mein Auto: 530i
I just read your post and was wondering what was the outcome because I am having that same problem ?
Old 05-28-2015, 01:11 PM
pcy pcy is offline
I replaced the Oil Filter Housing gasket and oil cooler gasket as a first step. Then I cleanup the entire area and have been keeping an eye. The leak/oil residue seems to have dramatically reduced.
If you know for sure the front main seal is leaking, there is a front main seal 'kit' available...
http://www.ebay.com/itm/BMW-Cranksha...-/311365136283
It doesn't seem to be that difficult other than having to remove the crank pulley. You will have enough room to work with after removing the electric fan.
