Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 08-28-2013, 08:03 AM
sovetcke sovetcke is offline
Mein Auto: e36 320i
Unhappy Hidden car issue, no body in my country knows how to fix it
Greetings forum,
Car Details: e36 - 1996, 320i Manual gearbox - Nothing modified.
I have been recently having a major shut down problem that no one can figure out in my country (Jordan)
The Problem:
Car shuts down while driving for the first time, So far once a day, and weirdly enough, at the same time of the day, but not while driving... which might be a pure coincidence
Cranks but won't start, as if no fuel is being transmitted, oil and battery lights become on, so i turn the key and it acts as if the battery is dead, but all lights are on, and even the radio is working... and won't start until i reset the car system (Disconnect the battery for a couple of minutes)
Sent it to a BMW electrician shop, they checked it by the computer, and he said it did not show any faults.
Mechanically checked almost everything, Fuel pump has been fully checked, changed fuel filter, thought it was the problem but apparently not.
Can you please recommend what do i need to look for ?
A mechanic is pushing me to buy a car computer + a Camshaft sensor, which i can't really afford at the moment.
Help is really much appreciated...
Thank you.
Old 08-28-2013, 08:24 AM
Mein Auto: e36 320i
I just noticed that i accidentally posted on the M forums, and mine is not an M power "Yet "
Please can an admin move it into the normal e36 section, as i don't want to flood topics.
P.S: i will post a video when the issue happens, to show you guys how it sounds exactly.
Thanks.
Old 08-28-2013, 01:55 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
You might have to PM an admin to get their attention.
I would check for vacuum leaks and get the alternator (including the voltage regulator) tested.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 08-29-2013, 01:24 AM
Mein Auto: e36 320i
Thanks bro, noted.
***UPDATE ***
Yesterday the car did not shut down, but today on my way to work it did,
I uploaded a video of what's happening when i turn the key, since maybe i can't exactly explain due to my english fail.
I tried to disconnect the Battery for 10 minutes, then 20 minutes, and still won't run.
So apperantly the battery reset was pure luck, since each time i got the car running again, i was playing around with the fuel pump.
So after trying with the battery and nothing... i opened the fuel pump, removed both of the electrical cables on it, and plugged them back in, and voila, car running again.
This might be that or that's just pure luck, i now have 2 options to get the car running again, either the fuel pump cables, or just waiting half an hour for it to run again.
Edit: Fuel pedal seems dead when it does that too
Old 08-30-2013, 02:21 AM
Mein Auto: e36 320i
** UPDATE**
My Mechanic got me a Crankshaft sensor and a computer for the car, he asked me to call him when it shuts down again (Which what it is not doing so far lol), as he wants to replace the computer when it's in the dead state so i don't spend weeks trying out stuff.
He insists it's the computer and told me that he wants me to praise his work and he is going to fix it, instead of one day saying that he failed, guy is a BMW nerd.
i'll keep you updated with this, so far it's not shutting down.
Old 08-31-2013, 05:06 PM
Mein Auto: e36 320i
Re: Hidden car issue, no body in my country knows how to fix it
Third day and still no shutdown, the car is scared
Sent from my GT-I9300 using BimmerApp mobile app
Old 09-03-2013, 07:15 PM
Smoothops Smoothops is offline
Mein Auto: 1995 BMW 318i Cabriolet
Sovetcke, where are the wires to the fuel pump? I'm having a very similar issue
Old 09-03-2013, 07:26 PM
Mein Auto: e36 320i
The 2 right on top of rhe pump as soon as u open it, not sure how they relate to the problem
But it worked last time... still no shut downs... but ill keep u updated till am 100% sure
I fixed it, my mechanic took it as a Chellange hah
Old 09-03-2013, 07:43 PM
Is that opening under the back seat?
Old 09-04-2013, 04:42 AM
Mein Auto: e36 320i
yep
Old 09-04-2013, 07:04 AM
I did find it thanks, disconnected the fuel pump, cranked the car, then re-connected it. No Joy. It will start if I put starting fluid in it though
Old 09-04-2013, 07:14 AM
Mein Auto: e36 320i
Did u try to disconnect the car battery for 10 min ? this wilp reset the computer. My mechanic narrowed the problem to a crank sensor or a car computer, I will replace them and see which as soon as it does it again, so far it still did not shut down.
Old 09-04-2013, 10:25 AM
The battery was out of the car for about 4 days, while I was working on the starter replacement. I will try again, see if that works for me.
