Finally time to fix my climate control properly - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 08-28-2013, 03:26 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
So I got my ac working a while back, but now the mornings are cooler and foggy. Now that school is back in i need heat and ac. So I BELIEVE i know the issue, but could not find much info.
My heater valves were not operating properly. I found the input to them was not correct, and did not change as it was supposed to do. I think it is my climate control module. Where is it?, can i fix it myself? I have checked everything. The aux pump is never off, and the valves get no signal to close when i turn the dials. So my guess is the module.
IF AND ONLY IF there is a way to repair it, and i attempt it. Would my fan and ac system still work to operate the ac right now if i mess it up or will my ac go out completely. Right now it works because i blocked the valves off.
The system just seems over engineered. It is great until it messes up. But there has to be a better way.
Anyway, and help is appreciated.
Old 08-28-2013, 04:04 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I'm not sure if there is a climate control "module", but I think that the operations are directed by the climate control panel (where the knobs and controls are).
Before I had my heater core replaced, I had either full hot or full cold whether it be AC or heat. I picked up a used climate control panel at Pull-A-Part and had my mechanic swap it when he replaced the heater core. Voila .... it works perfectly now.
If I recall, the panel cost around $20. Itís worth a shot.
BTW, if you remove your climate control panel and snap a pic of the back, it is possible that Andy (South26) may have one that matches it and you may be able to get it for a song
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-28-2013, 04:07 PM
Nothin like an E34
Thanks, that may be why i could not find much info, i only saw things mention climate control module. You wouldn't know how to remove it, i will search after this post.
Old 08-28-2013, 04:13 PM
BMR_LVR's Avatar
Humble E34 lover
Page 513-2 of the Bentley manual. It's pretty easy. Just be careful of the plastic parts that the cables attach to.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 08-28-2013, 06:12 PM
south26 south26 is offline
Mein Auto: 535i 1989
Happy to help and yes I could do it for a song. I have have both kinds of the hvac panel.
Andy
